The Bomb Shelter Take Cover ! All Off Topic Discussions , Anything And Everything Not Diesel Related Absolutely No Politics or Religion
V10 Swap F150 Help
Old Apr 12, 2012 | 09:52 PM
farmingsthelife's Avatar
Default V10 Swap F150 Help
Hey Guys, havn't been on in a while. Anyways, I need a little help. I helped this guy out keeping his lawnmowers running for years, and the other day he gave me his old f150 for free (well not too old-a 93!) It needs a new motor in it, (the old 302 is done!).
Well, I was looking for 351/5speed combos for sale on craigslist. All that stopped when I was told we'd be scrapping a v10 exersion left abandoned at the shop....and that I could have the v10 with the wiring harness inside it!
Now, I was left with the problem of a transmission. I ALSO found a free zf5 out of an 87 6.9 diesel.
Does anyone on here know if the zf5 from a 6.9 will bolt up to a v10 triton? If you can answer this question I'll owe you one, and will deffinentally give you props when it's done. Also any other advice would be appreciated. Thanks Guys!
Old Apr 13, 2012 | 11:07 AM
GuyWithA24Valve's Avatar
Well you won't know unless you try it. You could always make an adapter plate easy enough granted the input shaft fits
Old Apr 13, 2012 | 10:22 PM
tiremann9669's Avatar
You'd be farther ahead to buy a V-8 because you'll get tired of feeding that V-10 real soon.
Old Apr 16, 2012 | 06:46 PM
Ltk's Avatar
Ltk
i would imagine the gas mileage on the V-10 is around 5 gallons a mile +/-
Old Apr 16, 2012 | 10:01 PM
No you have it backwards it does get about 5 miles to the gallon
Old Apr 16, 2012 | 10:12 PM
RanchhandTCR's Avatar
I have a buddy with a 5 speed v- 10 and gets 12 MPH +/- There good for the mountains realy torqy SOBS, but yea hope its not your DD with $4 Gasoline. Who wants to go boring for oil?
Old Apr 17, 2012 | 12:01 AM
rjjp's Avatar
Not sure on the bell on the V10, but the ZF5 will have the same bell as a 7.3 PSD, slightly different from a BBF.
Old Apr 17, 2012 | 10:49 AM
Ltk's Avatar
Ltk
wonder what gets worse MPG? the puny 5.4 V8 under a 3/4 ton truck, or the V10?
Old Apr 17, 2012 | 05:48 PM
rjjp's Avatar
Running empty, they're pretty close, loaded the V10 gets better.
Old Apr 17, 2012 | 07:44 PM
Ltk's Avatar
Ltk
thats not too bad
