Possible solid axle swap
Old Apr 12, 2012 | 08:09 PM
TOM81650's Avatar
Default Possible solid axle swap
Does anyone know what it would take to put a 60 front axle out of a dodge in my 94 I know I'll have to weld spring perches on it but curious about steering
Old Apr 13, 2012 | 05:05 AM
DieselCrawler's Avatar
why not just get the correct 60 that BOLTS right in?
Old Apr 16, 2012 | 09:54 AM
TOM81650's Avatar
Not the easiest thing to find but am still lookin for one I was just curious we have an old dodge sitting out here with a 60 in it just didn't know how much it would take to put it in there
Old Apr 16, 2012 | 05:06 PM
to much. the hardest part is the driverside spring.
Old Apr 22, 2012 | 07:38 AM
6BT-F350's Avatar
Do yourself a favor and get a dana 60 from a ford like DieselCrawler said. My 85 had the IFS and swapping in the ford dana 60 was a piece of cake, all holes lined up, no welding or moving spring pads. Just make sure you get all the hardware with the axle.. Leaf springs, u bolts, tracking link, etc.
Some years of dodges had a right hand differential
Old Apr 30, 2012 | 04:57 PM
Bigred7.3's Avatar
also the dodge 60's are low pinion axles (at least every one ive seen or owned) the dana 60 is a high pinion and if u plan on going with a taller lift like 6inch or higher the dodge axle will really bring the front drive shaft angle down,
another option is what i had on my 94 f250 wat the solid dana 44 hd (8 lug) i wanted the 60 but the 44 was easier to find.
Old May 7, 2012 | 09:02 AM
TOM81650's Avatar
Thanks FoR the imput guys I tracked down the Dana 60 to bolt can anyone recommend a steering upgrade for it
Old May 7, 2012 | 06:11 PM
why? i run stock steering on mine and no issues with weakness yet.
Old May 14, 2012 | 10:58 AM
6.9idimonster's Avatar
those steering boxes take a whoopin. no need for upgrade.
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
blakec
20
Oct 18, 2014 03:35 PM
