New Fuel Only VP44 record
Old Apr 10, 2012 | 07:45 PM
GuyWithA24Valve's Avatar
Default New Fuel Only VP44 record
Did you guys see there's a new VP44 fuel only record? An '01 Dodge 2500 made 931 hp and 1,652 ft/lb of torque using a Monster 3 pump and triple turbos.
Here's the link
New "Fuel Only" VP44 Record | What's New Blog & Discussion at Diesel Power Magazine
Old Apr 10, 2012 | 07:51 PM
RAW's Avatar
RAW
Damn, and it looks like such a sleeper.
Old Apr 10, 2012 | 09:19 PM
Nutty Jeeps's Avatar
yep, I saw that to. wow
Old Apr 10, 2012 | 09:24 PM
cummin_un_glued's Avatar
FormerVendor
top feed injectors huh...wonder if they were KDELs? anybody got any more info on the truck?
Old Apr 10, 2012 | 09:44 PM
They could be John Deere injectors. I know some sled pullers run those
Old Apr 10, 2012 | 09:51 PM
FormerVendor
KDEL = John Deere
i have a set i been thinking about using in a later build
Old Apr 10, 2012 | 10:08 PM
Originally Posted by cummin_un_glued
KDEL = John Deere
Ah i see
Old Apr 11, 2012 | 06:05 PM
FormerVendor
KDEL just refers to the bosch injector body type, there are two styles one with 7mm nozzles and one with 9mm nozzles. Alot of the time shops will use the larger nozzles (large sac type) for the larger pintle but then turn them down to 7mm so that they will fit thru the hole in the head
my current 2.6 ppump 24v build has 6x.018 sacs that are similar but they are regular side enter bodys
Old Apr 19, 2012 | 12:41 AM
matt w.'s Avatar
Default All from.....
Pump, injectors etc. all came from monster pump mike.
Old Apr 19, 2012 | 07:12 AM
Hmm
Luke
