suspension.....
Old Apr 9, 2012 | 06:25 AM
minncountryboy's Avatar
Question suspension.....
Ok guys ive had my new truck for bout a month... And I've start to notice something in the front... Well sounds like somthing from the front... If I start to slow down it'll make one click noise.. and if i go over bumps or a bumpy corner its make a click noise.. seems like whenever the front suspension is workin it clicks.. I've had some people tell me it could be the front brake pads clip wiggled out n the pads sliding back and fourth in the caliper... But I'm kinda thinking differently.. I'm thinking maybe track arm bushings.. or something of that nature... Thoughts? Opinions?? Let's here em guys... Thanks for the help guys!
Cole
Old Apr 11, 2012 | 09:33 PM
Lurch's Avatar
sitting still, turn your wheel, lock to lock, and see if it pops, if it does, its your track bar. mines done the same thing every time.
Old Apr 11, 2012 | 11:07 PM
All right ill give er a shot tomorrow... I'm thinkin bout a different track bar anyhow since the guy i bought the truck from lifted 3-4" and didnt do a track bar relocation mount on it. Thank ya sir!
Old Apr 12, 2012 | 12:32 AM
Lurch's Avatar
i have the KORE track bar, its one beefy SOB, solid 1.5" commoly, adjustable. it comes with all the bolts and tabs you need, and no brakets needed
Old Apr 12, 2012 | 09:25 AM
I'll to go take a look at kore. Thanks for all info sir!
Old Apr 12, 2012 | 10:22 PM
Lurch's Avatar
no prob, let me know how it goes
Old Apr 13, 2012 | 12:04 AM
fp3's Avatar
fp3
is it a clunk(smaller noise) or a loud pop? a louder pop will be a track bar bolt not tight enough or an egged out hole, a smaller clunk will be a control arm bolt loose, odds are one of the upper arm bolts on the frame side. more than likely the passenger side.
Old Apr 13, 2012 | 12:09 AM
Well it wasnt the track bar.. ill have to try the upper control arm.. it sounds like its coming from drivers... Side.. ill have to check it out... Thanks for the help guys!!
Old Apr 13, 2012 | 11:30 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Ball joint,or U joint maybe?? Even if your trac bar is fine i would still put an adjustable in. i have never had good luck with a relocation bracket
Old Apr 13, 2012 | 08:10 PM
Well i don't think its a ball joint.. and a u joint I should be a able to feel the viberation. And it only clicks once when i slow down or go around a bumpu corner... but im thinking its the track bar cause it did when I was going through a tight parking lot with the wheels at full lock going to the right.
