fuel leak "help"
Old Apr 8, 2012 | 01:40 PM
THE REDDOG's Avatar
Default fuel leak "help"
Just got home from camping about 1/2 mile from the house started smelling fuel got to the house the complete driver side of motor and wheel well are soaking and dripping and could not find any thing leaking this is the second time it has done this.
Any help would be appreciated.
Old May 2, 2012 | 11:14 AM
Bigd-diesels's Avatar
Check the number 4 injector line, had to change mine twice now
Old May 4, 2012 | 04:27 PM
ThisisDC's Avatar
check ALL your injector lines. myne had tinytiny pin holes in them because of corrosion. once that happens, you have to replace em all. also check your oil. if your wayy high on oil and it looks clear, you have a bad injector and its filling your cylinder with oil and overflowing youroil pan. let me know what you find out
Old May 6, 2012 | 02:04 PM
dangerous1965's Avatar
Run it and LOOK! Wiggle the injector lines be carefull that's high pressure!
Old May 6, 2012 | 03:24 PM
tower_ofpower's Avatar
The return line runs up tight under the head behind the fuel filter canister. There's a rubber line that likes to rupture. Real pain in the nuts to replace.
Disregard this post; thought I was in a different forum.
Old May 7, 2012 | 01:30 PM
steved's Avatar
Since it comes and goes, I would suspect the seal in the CP3 may be failing...mine would leak once in a while, usually see the fuel dripping off its wiring harness. but mine never made that much fuel?
It would be worth your time to at least check the injector lines for tightness...I had one vibrate loose, and it created a fuel fountain under hood when the truck was running. but it didn't go away?
Dale9411
Dec 4, 2022 06:51 PM
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 08:30 AM
