triplets??
Old Apr 6, 2012 | 11:30 AM
blacksmoke82's Avatar
Default triplets??
ok i was gonna use these on my 12 valve but my 2004.5 has alot of lag. i have everything to run triples an from my thread in the 2nd gen area im gettin that the 3 turbos are normally closer in size, that being said will the 2 s359 s work better with the stock turbo on my common rail? its got a edge juice with attitude an the egts can run up near 1500 sometimes an theres a good amount of lag. so give me your thoughts will this work on my common rail better than my 12 valve???
Old Apr 7, 2012 | 11:35 PM
CHEMMINS's Avatar
Definitely would work better on the CR. The maps should be pretty similar between the s359's and the he351. It should give you close to a 2:1 pressure ratio.
What size are the turbine housings on the 359's?
Also, you must port the wastegate on the he351 to run trips. Heck, it should be done anyway as a single.
