Dually conversion
Old Apr 2, 2012 | 07:32 PM
Truck Guy99's Avatar
Default Dually conversion
Thanks for reading my post! (I'm not sure if this goes here, or in the potential owners department) I am thinking of buying a 96 ford 3/4 ton diesel from my neighbor, and I was wandering how hard a dually conversion would be with adapters. I know how to rotate tires, so is this something I could do? I know I would have to buy a bed so it would not look stupid. I was wanting to know if anyone knew of a good company that sold these adapters. I only tow 2 horses to the vet once a year and occasional small trailers of furniture. I know I can buy a set of dually rims at a junkyard, but I am open to internet links.
Old Apr 6, 2012 | 08:14 AM
94cummins12v's Avatar
why would you want a dually then? my dodg i bought was a dually and i took the duals and fenders off to make it a single 1 ton before i built my ford cummins. im actually using the doade dually axle in my current truck as a single
Old Apr 6, 2012 | 08:40 AM
Eddiebuntain's Avatar
I'm pretty sure J.C.Whitney has fender extensions to adapt the current bed to cover dual rear wheels, probably some other sources out there too. If I remember right, they also have weird spacer kits to run standard rims in a dual configuration, looks unsafe and goofy as hell
Old Apr 11, 2012 | 10:44 AM
I just like the look and towing stability of a dually, but the smoother ride of a 3/4 ton. If I do convert it, I would like a flatbed to haul protein tubs (about once or twice a month)and occasional round bails of hay. I guess what I am trying to say is I do not need the dually fender kit from JC, just adapters and a flatbed. Sorry for not mentioning that earlier.
Old Apr 11, 2012 | 11:28 AM
I'm not sure on that model, but I believe the rims are hub piloted, so you should just need the appropriate rims and lugnuts, possibly longer studs. If you want to complete the look with the steer axle, then you'll need adapters, maybe check with the site sponsors.
Oh, and post some pics if you do get the truck
Last edited by Eddiebuntain; Apr 11, 2012 at 11:28 AM. Reason: Automerged Doublepost
Old Apr 12, 2012 | 07:22 PM
Thanks! I did not think about needing longer bolts, so I appreciate that! Anyone else?
cummins.1.5.3.6.2.4
Sep 20, 2015 01:47 AM
CGwill
Jan 26, 2015 02:10 AM
joseywales
Jan 16, 2015 08:44 AM
Machinist
Dec 5, 2014 01:06 AM
sotomo
Nov 24, 2014 07:29 PM
