94 6.5L Slow crank
Old Mar 31, 2012 | 07:40 PM
mike14_07's Avatar
Default 94 6.5L Slow crank
My buddy dropped off his 94 2500 6.5L for to look at, he said it cranks real slow.(he doesnt speak great english and i speak even worse spanish) he dropped it off at the house while i was out, the batteries are drained so i got them charging tonight. i noticed he put 2 new batteries, an altenator, starter and all new cables. anybody have a cable diagram so i can make sure he has all that jazz right? also other things to check?
Old Mar 31, 2012 | 08:05 PM
wildbill's Avatar
Be sure he's got at least 2 650 CA/800 CCA minimum batteries installed. If that checks out, see if he ran a cable from one positive terminal to the other, then off that connection, another cable to the starter. Then check and see if he's got both ground cables hooked to a good spot on the block, steel bracket, etc...
Old Apr 1, 2012 | 09:08 PM
mike14_07's Avatar
k got the batteries charged and tested tested good, cranking speed is good, but the starter grinds like a sum bitch, it looks brand new, maybe a bad flywheel? anyone ever have to shim these?
Old Apr 1, 2012 | 11:23 PM
wildbill's Avatar
Does it still turn the engine over when the starter is en-gauged?
Old Apr 2, 2012 | 10:54 AM
mike14_07's Avatar
it just grinds found the front braket bolt to the starter was missing and the starter is cocked? anyone know the size of this bolt? also if the glow plugs are bad will that cause a starting problem in 80 degree weather?
ish1521
Aug 26, 2015 08:42 PM
Flikkie2001
Apr 2, 2015 01:36 PM
HeavyChevy95
Jan 11, 2015 04:31 PM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
coalrollink2500
Oct 15, 2014 07:17 AM
