Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
dmax woes. won't start
Old Mar 30, 2012 | 12:33 PM
mobetter's Avatar
Default dmax woes. won't start
having problems with my truck lately.
had loping idle. replaced the FPR with new stock bosch fixed that issue.
truck would stumble on acceleration, replaced FPRV fixed this problem.
truck has airdog lift pump, new stock filter, all new orings in filter housing.
truck has fuel pressure at the injection pump. all injectors bal are within tolerance.
I drove the truck for a week with no issues. now won't start.
diablo sport shows low rail pressure.
any ideals?
2004.5 lly
Old Mar 30, 2012 | 10:58 PM
DirtyMaximus's Avatar
Manually check your fuel pressure at the rail. Might need a fuel filter and or pump. Any engine codes?
Old Mar 30, 2012 | 11:55 PM
2004LB7's Avatar
check
Prime. try re-priming until bulb is hard
cranking RPM, batteries
injector return rates
CP3 return rate
anything else done to the truck? Mods?
Old Apr 2, 2012 | 08:28 AM
mobetter's Avatar
Default truck has airdog 100
the truck has a airdog lift pump and shows about 9 psi.
truck started fine the next day and has been starting fine the last few days.
injector balance is within spec.
cjgregory
Mar 31, 2015 01:45 PM
MANNCLAN
Mar 8, 2015 06:32 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
