Cummins non elctronic transmission??
Old Mar 26, 2012 | 08:54 PM
NauticaEE's Avatar
Default Cummins non elctronic transmission??
hey guys im new here and just had a question, im puttin a 96 5.9 in my 05 f350 as we speak, currently im building the 5.9 and was about to order the adapter plate and computer and flexplate for my ford trans but was wondering, is there a non electronic transmission that would bolt up to my 5.9? Being that I have the adapter and flexplate for a dodge trans already i was thinking of going that route instead, my goal is to be around 600-700hp in the end, thanks alot for any advice!
Old Mar 26, 2012 | 09:32 PM
H.R.D's Avatar
47rh
Old Mar 26, 2012 | 09:41 PM
deck60's Avatar
yep the 47 rh stick the money you would put in the adapter late into goodies in a 47rh they can be built so they are as strong as any of them
Old Mar 26, 2012 | 09:59 PM
NauticaEE's Avatar
awesome! thanks alot, would i be able to run a exhaust brake with this tranny too?
Old Mar 27, 2012 | 05:34 PM
deck60's Avatar
I don't know why not the exhaust brake has no real bearing on the tranny shift it should shift by rpm and mph on the 47rh there is a test port on the pass side rear of the trans where you can hook in a 45-55 psi ac switch this will enable your tranny to lock up od it goes psi= mph so if you are running 55 mph you are putting out 55psi
Old Mar 27, 2012 | 07:22 PM
NauticaEE's Avatar
ok well thats good, any idea what i should expect to pay for one that can handle 6 to 700 hp? also, will i be able to use my stock speedo and odometer some how? thanks man
Old Mar 27, 2012 | 08:56 PM
deck60's Avatar
spedo on a ford comes off the rear end almost like they knew what we would be doing
or a tranny I ran across this
Diesel Transmission Technology - DTT Performance Diesel Transmission and Power Accessories
Old Mar 27, 2012 | 09:00 PM
NauticaEE's Avatar
Sweet Ill call them tomorrow! sry for all the questions im sure ill have tons more thanks again
Old Mar 27, 2012 | 09:38 PM
deck60's Avatar
any time I do have a file I have of info from my build if you want it let me know I will send it to you
Old Mar 27, 2012 | 10:57 PM
NauticaEE's Avatar
Just got it going to go through it thanks alot!!!
