Need Help!!! A.S.A.P.
Old Mar 26, 2012 | 08:42 PM
Ted Legg's Avatar
Default Need Help!!! A.S.A.P.
I have a 1999 dodge 3500 4x4 woth the 5.9 cummins, 24v. I had some trouble a few weels back with it starting. It would start and then have a crazy lope in the idle amd then it would die, wouldnt take accelorator either. I replaced the cam sensor and it ran fine for about 3 weeks..... Then it done the same thing, so i replaced the cam sensor agian. Now its doing it agian after 3 days...... Any suggestions?
Old Mar 27, 2012 | 07:11 PM
welderboy250's Avatar
I'd guess it never was the cam sensor in the first place. Sounds like u may have a bad throttle position sensor and/or a bad injection pump.
Old Mar 27, 2012 | 07:48 PM
cummin_un_glued's Avatar
FormerVendor
have you scanned it for codes? with the idle problem i'm leaning toward bad ip since it should idle fine with a bad tps
