7.3 injector hold down bolts
Old Mar 24, 2012 | 06:06 PM
97t444e's Avatar
Default 7.3 injector hold down bolts
Ok im looking at buying some new injector hold down bolts and i guess there is a 48mm bolt and a 39 mm bolt what one is for a 97 PSD???
Old Mar 24, 2012 | 06:08 PM
fordornothing's Avatar
i hope you're refering to the length. one is longer and the othere is shorter. why do you want new bolts?
Old Mar 24, 2012 | 06:14 PM
97t444e's Avatar
the olds ones are stretched and dont want to risk one snapping off,
Old Mar 24, 2012 | 06:59 PM
oh ok. well you need both lenghts. 8 of the 48mm and 8 of the 39mm.
Old Mar 24, 2012 | 08:37 PM
97t444e's Avatar
why do i need 8 of both, there is only one that holds the injector down???
Old Mar 24, 2012 | 08:49 PM
there is 2 on each injector. when you remove the injector you only remove one. and the ring slides off of the othere one.
Old Mar 24, 2012 | 08:57 PM
95powersmoker's Avatar
How do we know they are stretched?
Old Mar 24, 2012 | 09:12 PM
97t444e's Avatar
i have them out of the truck right now and i can clearly tell they are stretched pretty bad
Old Mar 24, 2012 | 10:34 PM
well it's a 10mm head. you don't need to torque them down to 680 ft/ lb. so they really shouldn't be stretched...
Old Mar 24, 2012 | 10:49 PM
97t444e's Avatar
its the first time iv had them out of the truck since iv owned it i really donk know much about the history of the truck but im pretty sure some one over torqued them in the past
