Cant get help on Dmax Forum. Pedal wont work 03 lb7
Old Mar 24, 2012 | 02:03 PM
kyle_wheelz's Avatar
Default Cant get help on Dmax Forum. Pedal wont work 03 lb7
The Accelerator pedal just stops working. I have replaced, Accelerator Pedal sensor twice, Pigtail to Pedal, ECM, and i still cant figure it out! Fuel Pressure, and CP3 test great. Pedal will work, then just stop working on take off.
I have no idea what to do or where to check next....Could it be the PCM?
what else could it be??
Codes
p2133
p2139
p2140
they all are about the pedal, and i cant figure it out neither can my shop
anyone knows, 812-821-7277 you can call me or texting is faster
Old Mar 25, 2012 | 02:26 AM
2500HeavyDuty's Avatar
check all your grounds and clean them would be the first advice i would give.
Old Mar 25, 2012 | 02:33 AM
do you have a programmer on the box?
Old Mar 25, 2012 | 02:45 AM
2004LB7's Avatar
check out the attached file
codes indicate it is sensor #3 on the peddle
trace the harness from the peddle back to the next connector and check it with an ohm meter. all three sensors should read the same but #2 will read backwards.
if all is fine then it is probably the throttle actuator control module
Attached Thumbnails Cant get help on Dmax Forum. Pedal wont work 03 lb7-app_system.jpg
Old Mar 25, 2012 | 08:42 AM
my sensors dont read the same..
app1 - .7
app2 - 4.0
app3 - 4.4
and i still can figure it, thats y i replaced pedal sensor twice
i had EFI Live on it, then had them reflash compter to stock, then i replaced computer, and its still doing it without EFI on it
Last edited by kyle_wheelz; Mar 25, 2012 at 08:42 AM. Reason: Automerged Doublepost
Old Mar 29, 2012 | 08:10 AM
where is the throttle actuator control module located?
Old Mar 30, 2012 | 01:40 AM
2004LB7's Avatar
i think it is integrated into the ECM. do you have any tools to log/monitor the throttle position? EFI Live? see what the ECM is seeing
