What does it take to run 13's
Old Mar 24, 2012 | 08:01 AM
Kainedogg's Avatar
Default What does it take to run 13's
I have an automatic equipped '05 3500 Dually. It is basically stock except for a Smarty Sr, boost fooler, and an intake. What key mods are needed to get into into the high 13 second range? I am in the market now for an Airdog 150 for better filtration but my goal this winter is to get it quick on a reasonable budget.
Old Mar 24, 2012 | 02:54 PM
cummin_un_glued's Avatar
FormerVendor
what are you running the smarty sr on?
i've seen 4 dr swb 6 speed trucks do 13.8 on a smarty alone
Old Mar 24, 2012 | 04:55 PM
Kainedogg's Avatar
SW3, default settings.
Old Mar 24, 2012 | 06:55 PM
FormerVendor
a built trans a running the smarty sr on SW9 should get you in the 13s easy
Old Mar 24, 2012 | 07:16 PM
Kainedogg's Avatar
I hear the term built tossed around frequently but what does that really mean friend? Seems sky is the limit and I just want enough to make for a good DD with occasional 13's.
Old Mar 25, 2012 | 12:14 AM
FormerVendor
minimum billet input shaft, good valvebody and clutch packs
vin_diesel
Mar 1, 2016 01:43 PM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
clarthom
8
Mar 5, 2015 07:27 PM
wvwelder89
Nov 20, 2014 10:26 AM
