Just discovered a Cracked Exhaust Manifold...
Old Mar 16, 2012 | 01:53 PM
FirehouseSmoker's Avatar
Default Just discovered a Cracked Exhaust Manifold...
I have just discovered that I have a cracked Exhaust Manifold on my STOCK 06 Dodge 3500 Mega Cab. I started looking for a replacement and found several different brands from $150 - $850. I also found out from digging in glove box papers this is the 2nd time previous owner has replaced Manifold with original Dodge parts. Can anyone shed ant light on a Manifold that wont crack under normal conditions unlike these have ?
Also thinking of upgrading Turbo & adding Chip to my STOCK engine while I'm in there. Any suggestions on a new Turbo & Chip ? Not looking to make enough power for the sled, just enough to bump up my current power pulling my 30' Offshore Drone and Bobcat...
Thanks for the info. A two piece sounds like it would solve the problem. Any input on a new Turbo ? Don't know what Dodge installs stock to know where to look for upgrade size/ boost Turbo. Also seeing different size mm (blades/bearing ?) for turbo ? Can you/ anyone give me the cliff-notes explanation of different mm size? Gonna check you out in a few...
Last edited by FirehouseSmoker; Mar 16, 2012 at 01:53 PM. Reason: Automerged Doublepost
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
Old12er
Feb 20, 2015 10:35 PM
cummins Pride
Oct 23, 2014 01:10 PM
