Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Looking For Twins
Old Feb 4, 2008 | 12:28 AM
xtrm-s10's Avatar
Default Looking For Twins
looking into getting the super b twins for towing. is there anything else that I might need to get. Injecters or second cp3. stock 06 5.9 with edge adatude. I will be hauling 26-30,000 lbs
Old Feb 4, 2008 | 12:42 AM
2500HeavyDuty's Avatar
bigger brakes
Old Feb 4, 2008 | 12:48 AM
LOGANSTANFORTH's Avatar
injectors and a second CP3 wouldnt hurt anything.....
Old Feb 4, 2008 | 01:02 AM
2001shrtbedcummins's Avatar
well, for the twins, you will more than likely need more fuel than that. What are your goals for the truck?
Old Feb 4, 2008 | 01:15 AM
DangerousDuramax's Avatar
Dont get a second CP3 unless you like blowing up motors. Running twin turbos with a mildly modded stock CP3 will net you a far better return in torque with lower EGT's without putting a window in the block.
Old Feb 4, 2008 | 01:19 AM
Lostnwalmart's Avatar
dude those are weight reduction holes duhhhhh. you may want to look into some head studs as well.
Old Feb 4, 2008 | 01:32 AM
If you like weight reduction holes that completely stop an engine from running then be my guest. I've blown up 3 engines so I'm not real keen on anymore "weight reduction holes".
Old Feb 4, 2008 | 06:24 AM
xtrm-s10's Avatar
i will be hauling cars on a three car hauler up and down the grape vine I-5 so cal
Old Feb 4, 2008 | 07:59 AM
We're talking a cummins here, not a duramax. We don't have those problems with rods like you guys do.
