overdrive light
Old Mar 13, 2012 | 09:12 PM
cowboyford16's Avatar
Default overdrive light
Hey guys haven't been on years. I finally have a computer now . My 90 f250 has the overdrive light on the whole time I replaced the button still the same problem. The trans will manual shift fine but in drive it feels like its in third. The tach also doesn't work it stays at 0 all the time. Fuses are good. Could the tps be bad??
Old Mar 16, 2012 | 12:21 PM
"SmokinIDI"'s Avatar
that a possibility but all my stuff has checked out fine and i dont know where to go for now on.
Old Mar 17, 2012 | 11:34 AM
Alright hmmmm just got to ohm it now
Old Mar 19, 2012 | 08:37 PM
DieselCrawler's Avatar
need tach fixed.
Old Mar 19, 2012 | 09:03 PM
I need to fix the tach before I ohm the tps
Old Mar 28, 2012 | 10:20 AM
let me know what ends up workin for you because as of now im out of ideas and its still messing up
Old Mar 28, 2012 | 08:32 PM
the tach not working will screw with the e4ohno computer.
Old Mar 29, 2012 | 10:25 AM
well im not sure if your talking to me or him but my tach is working fine
Old Mar 29, 2012 | 11:24 AM
4x4manonbroke's Avatar
check the pick up on the injection pump housing area, it has two wires comming out of it, my understanding is thats the tach pick up.... might be another one but mines an 87.
not sure if thier might be one near the crankshaft, like a crank position sensor.
Old Mar 29, 2012 | 05:08 PM
nope. all IDI tachs are located on the timing gear cover.
