pulling the last of my hair out
Old Mar 12, 2012 | 10:11 AM
hookup's Avatar
Default pulling the last of my hair out
Not with my truck though. Pretty sure it doesnt have the power. Anybody know of hand what kind of boost the stock turbo should be producing?
Old Mar 12, 2012 | 11:49 AM
Grrrr's Avatar
30ish....mine peaks around 30 and drops back to 26-27
Old Mar 12, 2012 | 03:04 PM
coors_man_2005's Avatar
i could bounce 40psi and hold about 36-38 with my stock turbo not saying its good to do with the stocker with the drive psi it produces
Old Mar 12, 2012 | 04:11 PM
hookup's Avatar
See thats what I thought. I can only get about 10-12 and it is not running right. Also vibration starts about 4th gear and gets worse until 6th is steady drone and vibration. Driving me nuts. Just dropped new DD clutch in(man is it noisy) and vibration still there.
Old Mar 12, 2012 | 05:15 PM
EricBu12's Avatar
That's why I went with the Auto. I tow a heavy 5th and so far it has been perfect. I heard problems with the Manual Dual Mass flywheel and such.. didn't want that headache. My old 2001 5600 6 speed had problems too..
Old Mar 12, 2012 | 06:18 PM
hookup's Avatar
So any ideas? Cant think of anything that would cause low power, low boost, and vibration unless I have more than one issue.
Old Mar 12, 2012 | 06:24 PM
ya the dd's have some noise but i have never had no vibration
what about your map sensor is it clean and all the wires un broken i had a broke wire on mine and it would act up on me
Old Mar 12, 2012 | 06:49 PM
hookup's Avatar
I will check that when i get back. The issue was there before i changed clutch. The old factory clutch was slipping bad and throwout bearing was going. I was hoping that was problem with vibration. Needed clutch anyways
Old Mar 12, 2012 | 07:01 PM
tiremann9669's Avatar
I think problems arise from emissions equipment, probably need turbo cleaned or somthing. Delete whatever you can in your area seems to be the best thing you can do with newer trucks.
Old Mar 12, 2012 | 08:18 PM
Didnt even think about that was just assuming it was deleted. My buddies truck the
ebrake was sticking . We just did the deletes yesterday with smarty jr. Thanks to MIGHTY DIESEL
So that could be a prob with yours also. what do you have dont to your truck ?
put it in your sig so we all know and everyone can help out a little more
On the vibration do you have a carrier bearing on your driveline? Is it good? Have you checked ujoints ect.? My truck likes to eat ujoints
