01 lb7 wont start
Old Mar 11, 2012 | 04:05 PM
jbc's Avatar
jbc
Default 01 lb7 wont start
wont start no matter what new batteries and glow plugs while replacing plugs found coolant in number 8
Old Mar 11, 2012 | 04:16 PM
cummin_un_glued's Avatar
FormerVendor
start with checking the cranking rail pressure they take +-1400psi to start. if you have that and it wont start check compression in all 8 cylinders it should be 400psi or more.
also do a pressure test on the coolant system it it sounds like you have blown headgaskets on top of your no start problem
Old Mar 11, 2012 | 07:28 PM
jbc's Avatar
jbc
thanks man i knew it was probably HG but wondered why it didnt start
Old Mar 11, 2012 | 10:03 PM
FormerVendor
i'm gonna guess that your injector return rate is too high and that is causing the low rail pressure which is causing the no start condition
then if the coolant pressure rises over 17psi or so then you for sure have a head gasket blown but also it could just be the injector cup on the #8 cylinder also
mlknutzen
Chevy/GMC Duramax 01-04 LB7
Oct 1, 2015 10:56 AM
Paladin
Jul 26, 2015 03:59 PM
ronstop
Feb 26, 2015 09:48 AM
damanrescue
Dec 2, 2014 04:12 PM
Caleb C
Nov 17, 2014 02:06 PM
