05 DT466 HPOP?
Old Mar 3, 2012 | 09:20 AM
yanni1474's Avatar
Question 05 DT466 HPOP?
I have a 05 dt466. I deadheaded the hpop and only getting 500 psi of oil. When i t in a gauge from the pump to the head i get 500. Should the gauge go up really hi with the gauge on the pump alone? HELP!!! PLEASE!!https://www.dieselbombers.com/images/smilies/dash2.gif
Old Mar 3, 2012 | 02:32 PM
bobfbigman's Avatar
Not a %100 sure about this engine but I would think presure ought to be the same at pump and head, the presure will go up with rpm and is adjusted with the ICP and IPR. IS this the 7.3 motor?
Old Mar 3, 2012 | 09:38 PM
tiremann9669's Avatar
DT466 is a straight 6 like a Cummins
Old Mar 5, 2012 | 06:50 AM
yanni1474's Avatar
The truck will not start. It is a straight six inline. Replaced o-rings on oil manifold, icp and ipr.Micked out the oil o-rings to the correct specs.
Old Mar 5, 2012 | 03:25 PM
EasternAggie's Avatar
If you don't have enough oil pressure to fire the injectors, it won't start. New HPOP?
Old Mar 13, 2012 | 07:57 PM
farmingsthelife's Avatar
Seen a truck kinda like this at work. Would run all fine and dandy, then all of a sudden quit and no start. Replaced the ipr valve (i think, I'm still a greenhorn hahah i just follow orders) and the problem got better. THe truck would run fine, but occaisionally just die and not restart. Turns out the wiring somewhere (been christmas since this happened so I can't remember everything) on ipr valve was messed up from navistar, spliced our own stuff in there and ran like a champ. (till the lift pump went out, it's a real lemon of a truck). I don't really think that is your problem cause you said it won't run period, but double check all that wiring. Like i said it was the factory (connecter? I really can't remember) that was causing the problems. Hope this might help a little.
Old Mar 15, 2012 | 10:32 AM
cummins_guy's Avatar
what codes are you pulling?
do you have fuel in it ?
did it just stop and it now doesnt start?
is it smoking when trying to start?
you might have bad injectors, or leaking injectors.
bajahigh
Mar 24, 2015 10:12 PM
bigbadDT
Diesel Engine Conversions
Feb 26, 2015 06:48 PM
Stick_Welder
For Sale
Dec 28, 2014 10:16 PM
BlackOut96
94-98 7.3L Performance
Dec 11, 2014 07:24 PM
blakec
Nov 29, 2014 10:48 PM
