How To: Change CPS + My CPS Blurb
Old Mar 1, 2012 | 01:20 PM
A/Ox4's Avatar
Default How To: Change CPS + My CPS Blurb
Given how common CPS failures are, I felt a video was necessary. But, its pretty easy, so the last 1/2 of the video is me talking about the CPS and its basic functions.
In the video I talk about the CPS detecting the teeth on a gear. This is the gear in question. Notice the square holes in the gear? This is actually what the CPS is detecting, no the teeth. You will also notice that 2 of the squares are different sizes. These identify cylinder 1 and 4 to the CPS
Originally Posted by Ford Manual
The PCM receives engine rotational position information from the Camshaft Position (CMP) sensor. The CMP is a hall-effect device. It outputs 12 volts to the PCM whenever it detects the iron of a spoked target wheel in front of it, and it outputs 0 volts whenever it detects the space between the spokes. The target wheel spokes and spaces are each 15 crank degrees, except for narrow spoke which indicates cylinder No. 1 and a wide spoke which indicates cylinder No. 4 (fires 5th). The NGS PID RPM is generated by the PCM from the CMP signal.
Thank you to mueckster for the manual citation, and SnackDoc for the picture.
wlofton
11
Jun 26, 2018 08:58 AM
nomoney
Jun 16, 2015 08:16 AM
ctjkelley
Jun 3, 2015 06:01 AM
crusty
5.9L CR Performance
Apr 26, 2015 03:31 PM
