tranny cooler and line question
Old Feb 23, 2012 | 10:33 AM
gribble21's Avatar
Default tranny cooler and line question
I'm in the process of installing a new tranny cooler cause the stock one has a hole in it I mounted the new one back where my spare tire used to be and ran new lines up close to the bed to the tranny but the fittings i have for the new lines arent the same has the old ones on the tranny can anybody tell me what size fittings are on the tranny are they 1/2 npt or something else? Now for a second question I was following the stock lines and noticed they don't go straight to the stock cooler up front they go to a small box that's mounted just in front and above the tranny then to the cooler up front can anybody tell what that box it and if i can just bypass it with the new cooler? Thanks for your help.
Old Feb 23, 2012 | 10:58 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Is the box on the side of the engine?
Old Feb 23, 2012 | 11:24 AM
gribble21's Avatar
Yes I just looked at a different angle and its bolted right to the block what is it used for?
Old Feb 23, 2012 | 11:28 AM
1AMatt's Avatar
I forget the exact name of it but its a fluid to fluid cooler
Old Feb 23, 2012 | 11:38 AM
gribble21's Avatar
So do i need to run the new lines to it or can I just completely eliminate it?
Old Feb 23, 2012 | 12:03 PM
1AMatt's Avatar
No I dont think I would delete it. It probably works better than the air to fluid cooler
Old Feb 23, 2012 | 12:10 PM
gribble21's Avatar
So the engine coolent cools off the tranny fluid inside the box then the tranny fluid goes to the air cooler up front and then back to the tranny right? The new cooler I'm installing as a fan and is all by itself in the back so I think that would get plenty of air and cooling. Is it going to mess anything up if i do eliminate the fluid to fluid cooler?
mcompton1973
Feb 11, 2015 12:00 PM
BubbaDT55
Dec 7, 2014 08:52 AM
FlyingDutcman
Oct 28, 2014 04:56 PM
