6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Ds4 to db2 questions
Old Feb 22, 2012 | 06:03 PM
muderxtreme's Avatar
Default Ds4 to db2 questions
Im sure it's been covered before but I can't seem to find much online. I bought a db2 4126 off of an 84 sub non egr 6.2 for 80$. I couldnt pass up a cheap pump. Anyways, will the db2 flow enough fuel for my 94 1/2 ton 6.5td? It came with injection lines and everything. If I can't turn it up enough can I have it modified to flow more?
Old Feb 28, 2012 | 06:20 AM
great white's Avatar
Should, but keep in mind I'm a DB4 guy. DB2's came OE on the 93 TD's although you've got an older model DB2 there. 4911 was the 6.5 pump IIRC.
Bobby martin over on TTS has a conversion manual PDF you can download. At least he used to....
Not cheaply....crank the fuel screw and see whatcha get.....
Old Feb 28, 2012 | 12:17 PM
I did download his guide and it has a lot of useful information. Ive been trying to find fuel specs for the 4126 but nothing so far. Prolly just gonna install and crank the fuel screw and see how it runs. Do the studs on the back of the pump have the same thread pattern ( pump side) as a ds4? I know the lines are different but I didn't know if the stud thread pattern was te same
Old Feb 28, 2012 | 01:43 PM
Diesel Place : Chevrolet and GMC Diesel Truck Forums - View Single Post - Injection Pump Models, and Injectors!
I'm going to say it will bolt up, but that's just and educated guess.
Don't quote me on it.
That's also a pretty old pump....
Old Feb 28, 2012 | 02:21 PM
Well I know it's gonna bolt up I was just wondering about the lines. From what I've read they are different lengths and the fitting on the pump side is different from a 6.5
Old Feb 28, 2012 | 03:53 PM
Pump side fittings are different from 6.5 lines.
Not sure on the length thing...I'm gonna guess they're the same...
Old Feb 28, 2012 | 04:57 PM
Ah okay. Thanks for the info. Gonna do a swap next time I get a few days off work.
Old Mar 1, 2012 | 09:39 AM
ebarresi5894's Avatar
please take pics!
Old Mar 1, 2012 | 08:00 PM
Originally Posted by ebarresi5894
please take pics!
Funny that I get the notification of your reply after I put everything back together. Is there any pictures in particular you are wanting to see or just of the process in general? I couldn't get it to start so I may be swapping the ds4 back in for the time being until I can get this db2 to a shop to see what's the matter with it. (fuel to pump, solenoid on, no fuel to injectors)
Old Mar 6, 2012 | 04:13 AM
I pulled the db2 back off and it's making a strange clicking sound an it turns really easily. My ds4 is pretty much silent when you turn it and it has some resistance. Any thoughts? Also, I took some pictures of each step of taking the pump back off if anyone needed them.
4x4kingx889
5.9L CR Performance
Sep 10, 2015 03:45 AM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
