6637
Old Feb 22, 2012 | 03:46 PM
Mainer815's Avatar
Default 6637
Hi i put a 6637 filter on my truck and i was wondering what to do with the sensors that were in the stock airbox? is it ok to just leave them unplugged?
Thanks
Old Feb 22, 2012 | 06:10 PM
Clark Kent's Avatar
Thanks
Hello Mainah, north of Bangor guy here. A stone's throw away from The County really. I used a pvc elbow on my intake and just drilled and placed the what I believe is an air intake sensor into it. The vac/filter sensor can be left off or you could drill and tap the black part of the filter and drop it in.
Old Feb 22, 2012 | 06:18 PM
fordornothing's Avatar
that's just the air intake temp sensor. just zip tei it to the brake master or something.
Old Feb 22, 2012 | 06:24 PM
DieselDanBoy's Avatar
there's a hole in the drivers fender it fits into faily well
Old Feb 23, 2012 | 04:18 PM
Mainer815's Avatar
Thanks for the help. Does that sensor have anything to do with my ebpv? Since its been unplugged the valve doesn't do anything.
Old Feb 23, 2012 | 05:16 PM
95powersmoker's Avatar
It shouldn't have changed the way your EBPV functions. Are you sure you didn't disconnect the plug under the intake side of the turbo for the EBPV?
Old Feb 23, 2012 | 05:26 PM
Mainer815's Avatar
I'm pretty sure I didn't but anything is possible. I will have to check this weekend
Old Feb 23, 2012 | 09:19 PM
A/Ox4's Avatar
I have heard that the IAT sensor and the EBPS both contribute to a similar goal, however the EBPS and EBPV are not related.
