Getting a 24 Valve to 800 Horsepower Safely.
Old Feb 21, 2012 | 02:38 PM
robertchase199's Avatar
Default Getting a 24 Valve to 800 Horsepower Safely.
I want to get my 1999 24 Valve to 800 horses safely. I've heard lots of talk of ppump conversions but i want to stick with the electronic controls. I know i have to build the tranny and do the head studs and such, but as far as fuel pump lift pump possible electronics and turbo set up, how should i go about that?
Right now ive just got a k&n filter, turbo silencer ring pulled and a straight pipe done. I want to get the transmission done in the next few months after that i want to work on the fueling system. Any advice guys?
Old Feb 21, 2012 | 08:05 PM
empty wallet's Avatar
Do fuel system first. You won't make 800hp on an s.o, h.o, or hotrod vp44. You need either a monster pump or a p-pump, and that's a small chunk of change compared to what else you'll need... do you realize 800hp is a pretty high number? I hope you have deep pockets.
Old Feb 22, 2012 | 01:18 AM
01quadcab's Avatar
you will not I repeat not hit 800hp on fuel alone you will need the juice. big injectors, compound turbos or a big single edge drag comp, o-ring head. fass 150 110# valve springs, titanium retainers and a shop that knows how to make it all work. I see yours is a 99 better check for a 53 block
Old Feb 22, 2012 | 03:33 AM
globalwarmingcontributor's Avatar
i need to check and see if i have a 53 block... i hope i dont!!!!
Old Feb 24, 2012 | 02:52 PM
turbo20psi's Avatar
If you are going for the 800hp the transmission needs to have all billet shafts and possily a billet drum,3 disk TQ valve body. You better p-pump the truck, port the head and 110# valve springs( I would use a CR head off a 2006 truck ) you will need a cam, compounds, water-meth, a better intercooler, traction bars, polt inserts for the motor mounts,
Old Feb 26, 2012 | 07:13 PM
VPpower2002's Avatar
LOTS of fuel... i have 7x.023 injectors and large nitrous nozzles with hopes to reach that number +
Old Feb 26, 2012 | 08:07 PM
mysterync's Avatar
Yup lots of fuel, a single and lots of juice...
Sent from my DROID BIONIC using Tapatalk
Old Feb 26, 2012 | 09:29 PM
cummins270's Avatar
7x.023's? Those are huge! Who made them and what pump are you running?
Old Feb 27, 2012 | 08:54 PM
I want to get the fueling system set up to run in the direction of 800+ work on the turbos next and getting the block built to handle the extra ponies. Then start work on tuning it for max horsepower.
Old Feb 27, 2012 | 09:02 PM
mysterync's Avatar
Better start pulling the head, buying lots of parts and find someone with a dyno.
