12 valve running rough
Old Feb 20, 2012 | 08:58 PM
AFX's Avatar
AFX
Default 12 valve running rough
I gott a 95 12 valve automatic that i rebuilt recently with new pistons, arps, an hamilton cam. Also had some porting work done on head also. Got 5-12 SDX injectors with 4000 gov springs, rack plug, air dog 100, and some afc mods. Any how after a few miles of test driving it started missing real bad at any rpm over an idle. Bluish grey smoke and couldnt get over 500 rpms without stumbling really bad.
Did my pump gears slip and the timing is retarded? I had it set at 19 degrees BTDC
Old Feb 21, 2012 | 09:48 AM
daveO's Avatar
I think it would def be worth checking the timing.
Old Feb 21, 2012 | 01:38 PM
EasternAggie's Avatar
Ditto. Those are some common signs of slipped timing.
Old Feb 21, 2012 | 03:28 PM
AFX's Avatar
AFX
Thanks guys ill look into it!
Old Feb 23, 2012 | 09:10 AM
cummins_guy's Avatar
if it is before top dead center, your timing is not 19* it would be less.
blue smoke or blueish, means oil being burnt, have you checked your turbo.
hope it helps
ssmith.77
Nov 25, 2018 06:56 AM
ssmith.77
Jan 11, 2015 02:03 PM
f250white
Jan 11, 2015 09:25 AM
Fishy816
Jan 11, 2015 08:31 AM
cmalson
Nov 29, 2014 12:57 PM
