Tunner/programmer
Old Feb 20, 2012 | 09:23 AM
MonsterStroke's Avatar
Default Tunner/programmer
hey everone. I am looking to buy a tunner/ programmer for my powerstroke.I have pick out 2 different brands. A bully dog Pmt and edge cts with juice. Any thoughts on the 2 or any other brand that i should get. Thanks.
Old Feb 20, 2012 | 09:38 AM
CMCA Swartzkrautheim's Avatar
Ts six position custom tuning for exactly what's done too your truck and much more versatile...JMO
Old Feb 20, 2012 | 10:44 AM
95powersmoker's Avatar
I would also go with a TS 6 position...
Old Feb 20, 2012 | 01:01 PM
The truck has a 4inch exhaust from turbo back, and intake, planing on putting stage 2 injectors, biger turbo, shift kit, and a new intake man.
Old Feb 20, 2012 | 05:53 PM
fordornothing's Avatar
TS all the way. you can get custome tunes to optimize the injectors. bully dog and edge you are stuck with their tunes.
Old Feb 20, 2012 | 11:11 PM
COLETRA1N's Avatar
Dont get either of them, you need a chip and I would get mine from PHP or DP
Old Feb 21, 2012 | 09:22 AM
Ok. thanks for the help.
Old Feb 21, 2012 | 09:40 AM
joebob3093's Avatar
Moderator
the edge and bullydog are meant for stock injectors so if you are wanting to get the full potential out of stage 2s you would need a custom tuned chip. also unless you are planning on running stage 2 split shots which would be oil hungry SOB's the pickup will not run right.
Old Feb 21, 2012 | 08:50 PM
upgrading the oil lines would fix the oil hunger?
Old Feb 21, 2012 | 08:59 PM
joebob3093's Avatar
Moderator
larger oil pump, T1000 or dual pumps is what i would run. or you could get single shot injectors and a custom TS chip and still run the stock oil pump.
