injector % usage vs supporting bombs
Old Feb 19, 2012 | 10:49 PM
CumminsCrazed's Avatar
Default injector % usage vs supporting bombs
hey guys im looking at a set of 7x0.012 (150hp) injectors for my truck in the very near future.
what im wondering is how much of the additional 150 hp will be useful with my CURRENT set up. i WILL be adding a bigger turbo down the road as well as possibly water/meth etc to help with heat.
Anyway heres my current set up as well as i can list. Let me know how much power of the injector will actually be used vs just creating heat and smoke.
FASS 150
Hx35 (stock turbo)
Edge Drag Comp (pump wire pierced)
Boost Elbow
Amsoil air filter intake
SBC SDD-3600
4" DP-5" exhaust
Im thinking thats about the max for big parts on my truck, and obviously some of these arent at all related to the question im asking, but regardless it may clear up additional questions etc.
Anyway, let me know how much additional power i will actually gain out of these injectors above whats im currently at power wise.
Old Feb 20, 2012 | 12:58 AM
01quadcab's Avatar
way too much injector on an hx it's will be toasty. save the injectors and install with a turbo. I would say your turbo will not last long before it gets too much boost and gives up. it will also be pretty smoky
Old Feb 20, 2012 | 12:22 PM
You will have to turn your edge down until you get a larger turbo.
Old Feb 20, 2012 | 06:22 PM
well thats my plan, turn edge down or off and run mainly on injectors themselves, but no ones answering the question i wanna know, which is how much of the power of the injector will be usable with the current set up im running
Old Feb 20, 2012 | 07:15 PM
empty wallet's Avatar
You'll notice a difference, more fuel is more fuel, you'd be surprised what an hx35 can clear up... just hope you have a built tranny. but on the flip side of that it only took a few months for my HX to show the signs of serious abuse/misuse... it was blowing oil and ended up with some serious shaft play even with wastegate set to 34psi when I was running 150's. so as 01quadcab said, you're asking it to go above and beyond it's capabilities... last thing you wanna see is it grenade a wheel.
Old Feb 20, 2012 | 10:22 PM
dont care if it blows.....gonna run a 64 on it before too long
Old Feb 21, 2012 | 08:04 AM
RAW's Avatar
RAW
I'd say 50% max, the rest would be going out the pipe in a cloud of black.
Old Feb 21, 2012 | 05:42 PM
OK SO 75HP OR SO, COOL THANKS BUD!
Old Feb 24, 2012 | 01:13 AM
jake 94's Avatar
I thought 7x0.012s where 250hp??
Old Feb 24, 2012 | 02:00 AM
Ya should be around 240
Luke
