Convert Open Differential to Limited Slip
Old Feb 19, 2012 | 01:43 PM
Lucky13SGT's Avatar
Default Convert Open Differential to Limited Slip
Fellow Bombers,
My 06' Ram 2500 has the open diff and I want to convert it to the limited slip for the off-roading advantages, how do I do this and how much does it generally cost? Need all the help I can get with this one.
Thanks,
Lucky
Old Feb 20, 2012 | 10:21 AM
cummin_un_glued's Avatar
FormerVendor
you have to remove the carrier and swap your ring gear over onto the LS carrier then you have to reset the shim packs to get your gear pattern back where it needs to be, cost just depends on which LS you go with and if you go ahead and do carrier bearings while your in there
Old Feb 22, 2012 | 08:37 AM
dangerous1965's Avatar
Your looking at a grand!
Colbyflory
Aug 16, 2021 09:19 AM
