Died while driving *Update*
Old Feb 18, 2012 | 06:26 PM
97dieselnewb's Avatar
Default Died while driving *Update*
OK my truck died while driving it the other day and will not start back up.. It wants to and it turns over strong.... But no go, so ive done the following:
checked the alternator
new batteries
changed the cam position sensor
drained the fuel bowl and it's refueling
changed the valve cover gasket and wiring harness's
checked the HPOP for oil
checked the fuses
I just got the following codes:
P1280- injector control pressure circuit out of range- low
p0381- glow plug indicator circuit malfunction
p0603- PCM processor keep alive memory (KAM) error
ANY help would be appreciated
Old Feb 18, 2012 | 07:12 PM
95powersmoker's Avatar
Unfortunately none of those codes mean much...
While you have the valve covers off, crank and see if oil is coming out of the injector oil deflectors...
Old Feb 18, 2012 | 08:09 PM
why don't the mean much...? the first code from what i've researched means theres a problem with the ICP and if i'm putting two and two together right... wouldn't that be causing my problems? and the truck is already put back together.
Old Feb 18, 2012 | 08:16 PM
the 0603 is from disconnecting the batts, the 1280 has to do with ICP but if you unplug the ICP sensor and try to start it, the computer will return to a default table of values... If it starts without the ICP sensor plugged in, then you've found your problem...
Old Feb 18, 2012 | 08:30 PM
well i unplugged the sensor and tried to start it and it still did not... the only thing that happened different was the check engine light came on...
so why are those codes coming up?
Old Feb 18, 2012 | 08:36 PM
That's why that code popped up... That's why I said it didn't mean much.
Are you getting smoke out the tail pipe at all when cranking? How's the oil in the crankcase?
Do you live anywhere near somebody with a scanner that can read powerstrokes? knowing the ICP and Duty cycle will help this diagnosis.
Old Feb 18, 2012 | 08:38 PM
no im new to the area i am at fresh oil change so the oil level should be good and clean... and no smoke when i crank it before it died... on cold mornings it there would be white smoke and if it was really cold or sat for a couple days there would be no throttle response until the truck warmed up for about 30 seconds to a minute
Old Feb 18, 2012 | 08:44 PM
That's typical of a cold diesel, you should always warm it up for a few minutes before driving. Does your Wait To Start light come on and go off like normal? Did you unplug anything like the IDM or PCM harness?
Old Feb 18, 2012 | 08:48 PM
Yes the light comes on like normal... also when its cold.. it sounds like its dieseling when i drive it sometimes...
no to unplugging the harnesses... I just found out the IDM harness is behinf the drivers side fender well? and Where is the PCM harness... if you have pictures that would be awesome.
Old Feb 18, 2012 | 08:59 PM
No, your IDM sits right in the engine bay on the fender well. It's not behind it like on the Superduty's. The PCM sits behind the ebrake, but the back of it is visible on the firewall.
