Stage 3 injectors
Old Feb 14, 2012 | 07:35 PM
97t444e's Avatar
Default Stage 3 injectors
Im am curious to what iv heard from people regarding stage three injectors. They claim that stage threes can be ran on a stock turbo and stock fuel system. Thay stated that they just had the injectors tuned to a really low level close to stock so it would not hurt anything. It there any truth to this? BTW the trucks were a 96 and a 94.5 powerstroke.
Old Feb 14, 2012 | 07:37 PM
joebob3093's Avatar
Moderator
Yes you can detune the injectors. Read the injector sticky
Old Feb 14, 2012 | 07:48 PM
97t444e's Avatar
ok i will check it out!
could i get the link to the injector sticky?
Old Feb 14, 2012 | 08:18 PM
joebob3093's Avatar
Moderator
Should be at the top of the page. If not its at the top of the SD section
Old Feb 14, 2012 | 08:58 PM
97t444e's Avatar
ok thank you
so if you wanted to you could make 238/100s run at the same level as the stock 90cc injectors?
Old Feb 14, 2012 | 09:11 PM
joebob3093's Avatar
Moderator
You could make it run at 5hp if you wanted
Old Feb 14, 2012 | 09:39 PM
95powersmoker's Avatar
Just pick an injector that you can afford and fits your goals for the truck and run it. IMO, get the injector that fits your goals. Having the biggest injector isn't going to get you anywhere if you cant afford to run it. If you want 400 hp, a 160/80-100 will get your right there with supporting mods.
https://www.dieselbombers.com/ford-p...ok-inside.html Here is the sticky thread...
https://www.dieselbombers.com/99-03-...tml#post528193
truckerchuck76
Aug 14, 2015 10:46 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 9, 2015 08:27 PM
DPRacing805
For Sale
Nov 15, 2014 12:47 AM
