Tune levels
Old Feb 7, 2012 | 04:35 PM
Smokey99's Avatar
Default Tune levels
Need help just got a smarty to stack on my edge comp and was wondering what levels to run the smarty at
Old Feb 7, 2012 | 04:40 PM
H.R.D's Avatar
Run the smarty on levels without added timing. Should be even number levels but read the supplied literature to confirm.
Old Feb 7, 2012 | 05:26 PM
Smokey99's Avatar
The higher the number the more power correct?
Old Feb 7, 2012 | 05:38 PM
Smarty=Cummins's Avatar
Yes keep the Smarty on even numbers let the edge do the timing. The Smarty puts out 65 hp to the wheels. I'm pretty sure the smarty is at 65 hp on all of the levels I THINK. Its just on level one its not very aggresive and as you go up in the numbers it will get more aggresive. I run my smarty on 2 with the Timing 0, Torque 4, and Duration 4 and the edge on 3 Im pretty happy with it im getting 18 mpgs with all the power I want for now untill bigger turbo
Old Feb 7, 2012 | 05:42 PM
H.R.D's Avatar
No, the higher the level the more aggressive the fueling curve is. It still gives you the 65hp across the levels it just changes the low end responsiveness. On a VP powered truck without tapping the pump wire you can only achieve 65hp over stock out of the IP.
Sep 21, 2015 06:10 PM
crpmap
Ford Powerstroke 08-10 6.4L
Aug 16, 2015 07:38 AM
crpmap
Jul 29, 2015 11:01 PM
Gorder14
Apr 15, 2015 08:29 PM
justinsbeck
13
Oct 29, 2014 03:25 PM
