Exhaust
Old Feb 1, 2012 | 11:03 AM
Crazy's Avatar
Default Exhaust
I am getting ready do some mods and updates on truck here in about 2 weeks
1st - new IP and Injectors timing turn up fuel and boost and also add E-Pump
2 sec - open up air the system and maybe add inter cooler
3rd - add gauges (EGT, Boost, and Trans )
4th - get 3 " dp from banks
I been looking on line trying fine 4 inch exhaust back from 3 inch dp haven had luck fine one can some one point to site.
Will 4 inch exhaust from power stroke work with banks DP ?
Thanks for any info i can get and if missing something let know
Thanks Bruce
Old Feb 1, 2012 | 12:01 PM
91dirtydiesel's Avatar
5" straight pipe!!! 4" intake with cone filter!!!!
Old Feb 1, 2012 | 02:35 PM
"SmokinIDI"'s Avatar
im running 4" into 6" stacks and it sounds sweet
Old Feb 1, 2012 | 02:41 PM
Crazy's Avatar
K what size pipes should be run to get the most out of the truck.
Old Feb 1, 2012 | 02:45 PM
doesnt really matter when it is straight piped bigger than like 4" or so because the more easier the air flows the best performance you will get. so if you have a muffler or CAT then they will slow down the flow of your exhaust which is holding the truck back.
Old Feb 1, 2012 | 04:07 PM
Crazy's Avatar
Here what i want to get will this work with the banks DP
DIAMOND EYE 1994-1997 FORD 7.3L POWERSTROKE 4" TURBO BACK DUAL EXHAUST SYSTEM
Other ? i for got to ask. The DP from banks does it fit right in place or do have bend the fire wall to get it fit
Old Feb 1, 2012 | 06:06 PM
DieselCrawler's Avatar
firewall might need slight tweeking, and yes that kit will work, might need a little adapting but can be made to fit. all the hangers are the same for the 92 to 97 trucks.
Old Feb 1, 2012 | 06:13 PM
Crazy's Avatar
? here from what i want do from my first post how much of a gain in HP can i see and when put the new put on what should have time at now remember i am not setting this up HP power trying set it up for towing my 5th wheel that's 16,500 lbs
Old Feb 2, 2012 | 07:09 PM
not really going to notice much power gain. maybe 10-20 hp, MAYBE.
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
