Help! Rear main seal!
Old Jan 31, 2012 | 06:24 PM
BramanteCummins's Avatar
Default Help! Rear main seal!
So I'm posting this for a buddy of mine. He's got a 99 PSD, he straight pipe it, did a big filter and then got a tuner for it. I believe it's a super hips flashPac. Well while he was investigating his leaky oil pan he noticed the rear main seal on its way out.
The truck never dripped all that much oil, now he has to keep up with it, high crankcase pressure from the programmer?? Or just a coincidence?
Old Jan 31, 2012 | 06:33 PM
fordornothing's Avatar
is he sure it's the rear main? really check cos it might be turbo pedistol o rings.
Old Jan 31, 2012 | 06:54 PM
I'll relay the message
Old Jan 31, 2012 | 09:20 PM
95powersmoker's Avatar
Look in the valley of the motor... Oil will leak from anywhere in there and run down the back of the motor looking like the rear main...
Old Jan 31, 2012 | 10:14 PM
Thats what it appears, theres oil higher than th seal. Will be doing further investigation!
Old Feb 1, 2012 | 08:01 AM
CMCA Swartzkrautheim's Avatar
Yea I just fixed a leaky hpop line that was seeping into the vally now she's runnin a lil smoother
Old Feb 1, 2012 | 10:08 PM
OceanDiesel's Avatar
I've had to do HPOP o-rings due to some bad leaks, and the whole time I was thinking rear seal. Now that my pan is leaking, I'll more than likely just do it while the engine is out.
Old Feb 1, 2012 | 10:52 PM
hpop?
Old Feb 1, 2012 | 11:55 PM
gradyc's Avatar
HPOP is high pressure oil pump. The o-rings and hoses are a source of most of the oil leaks that at first look like a rear seal.
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
Max713
Apr 17, 2015 01:20 AM
wildbill
Jan 31, 2015 11:14 AM
