cannot figure this 6.5 out! help!!!
Old Jan 28, 2012 | 08:41 AM
ebarresi5894's Avatar
Default cannot figure this 6.5 out! help!!!
okay, so i just bought a 1995 K2500 VIN F
it would not start at all, so i charged the batteries and it finally cranked good.
it is getting fuel, (cracked the bleeder on fuel filter), and it has pressure.
cracked the injector line, and its getting a little fuel.
my first thought was the PMD, so i took the one from my RUNNING truck and plugged it in.
took about 2 mins with fully charged batteries, and i finally got it to kick over.
it was running very very rough (pop fart and spit every 5 secs) and then i kept it at about 2 grand and it would run fine.
so now i figured that hey, this runs let me take it down the street. drove it for about 2 miles, and sure enough it dies. would not start, cranked and cranked.
HOWEVER, i cracked the bleeder again, and air bubbles, but the fuel pump works.
so i cranked and cranked with the system bled, still nothing.
when i got it back home, i plugged it into the charger, and sure enough, started it up to put it away.
so with the good PMD, it still is having PMD related issues.
im guessing that the PMD was fryed because it was in the hot spot (manifold), so i used mine like a said.
the fuel shut off solenoid was replaced, along with the fuel pump relay, PMD (mine), and the OPS.
im thinking about trying the lift pump, the brain, and i dont belive its the sending unit if its getting clean fuel.
any help with this would be great i appriciate so much
Old Jan 28, 2012 | 10:13 AM
Crazy's Avatar
Old fuel maybe
Check around fuel housing they are know to leak and can't see it with out removing lot time O-ring and seal for heater and water senter leaks suck air fast into the system
try unpluging the OS harness filter and just plug harness wires right bad in the IP
Other thing try is unplug the ECT start it see how idles
Check all the grounds
Old Jan 28, 2012 | 04:40 PM
another update...
i jump the relay, and the fuel pump works. i put a brand new regular relay and i got under the truck and the lift pump has no power unless i have the jumper relay in.
Old Jan 28, 2012 | 10:12 PM
Crazy's Avatar
OPS on 95 tell the LP to work and it will only do this when you have key in the run pos.
Old Jan 31, 2012 | 07:27 AM
thanks crazy, i appiciate the knowledge
but what i ended up doing was running a jump wire from the radio to the lift pump, so this way it will run whenever the key is on, like an OBD II.
it does run now,
however, when i mash down on it it still feels like it is intermitting power, so im not sure if the lift pump is just not running to full potential, or the fuel filter is dirty, etc ill have to look today
any input would be great
So I drove it down the street today and it died again..
Thats with the hot wired pump..
So im thinkin about buying a new pump and another ops.
Last edited by ebarresi5894; Jan 31, 2012 at 07:27 AM. Reason: Automerged Doublepost
Old Jan 31, 2012 | 09:29 AM
Crazy's Avatar
Did you try swapping the PMD. It starting to sound more like PMD if you hot wir the pump OSP won't shut down now
Call me if you want to
Old Jan 31, 2012 | 09:51 AM
i did try that before i hot wired the pump. the only thing is, every time i crack the bleeder on the fuel filter, air shoots out then fuel.
Old Jan 31, 2012 | 09:58 AM
Crazy's Avatar
look around fuel housing they like to leak around the fuel heater the O-ring goes bad check fuel lines right there also they get dry rotting over the yrs from heat
How the return lines look could be sucking air
It could be weak LP the only way for sure is to put fuel pressure gauge on it see what read at idle and under a load
Old Jan 31, 2012 | 10:11 AM
where do i hook it up? the T valve right?
Old Jan 31, 2012 | 10:16 AM
Crazy's Avatar
yes hook up on the T-Valve just take the drain line off and hook up there open the T-Valve and take for ride see what the PSI are under normal driving and with foot to the floor and at idle
at idle should be around 9 to 12 psi
normal driving 7 to 9 psi
foot to the floor 3.5 to 6 psi
