Fuel Problems
Old Jan 27, 2012 | 05:15 PM
Crazy's Avatar
Default Fuel Problems
My truck been loosing it fuel prime every so offing it not all time i maybe able go 3 days or it maybe 5 mins after shut the truck
Like left work on monday drove 2/10s mile stop get fuel come back out truck loose it prime reprime the system drove home got up next morning started right up went out at lunch go get something no start loose it prime again reprime system again drove 2 days no problem get this morning start and die had to reprime system
I have look and look can't fine no fuel leak, the return lines kit is 2 months old are new all the injector are dry new fuel filter one peace spin on filter also new fuel housing
Does the fuel pump have chuck valve in them to stop it from draining back ?
Ok looking any idles where to and look for need get this fix fast wife going be driving the out state in few days don't need this breaking down on her
The truck does run fine go down the road and it idling
The truck was not low on fuel they had 1/2 tanks in them
Thanks for any help anybody can gave me
Bruce
Old Jan 27, 2012 | 08:42 PM
DieselCrawler's Avatar
just outa curiosity, check your oil..
Old Jan 27, 2012 | 08:46 PM
Crazy's Avatar
Yes i did not making any oil i thought maybe the LP was leaking into the crack case
Old Jan 28, 2012 | 12:48 AM
no idea then bud.
Old Jan 28, 2012 | 10:07 PM
Crazy's Avatar
Default Update
Well think found the fuel problem, I tink it was my starter being the problem not spinning over fast enough went to the store today and came out and didn't spin over at all had truck tow home ( think god for AAA ) did some testing batterys are and was load testing good had 13.5 v in both so took the meter and work my way back to the start had 12v all way to starter then put amp meter on it bingo. So got me to thinking truck wasn't spinning over fast enough so my think was LP couldn't keep up with the fuel and the IP was suck all the full out filter. so fine out here with in next few days here been banging head up against a wall looking for fuel leak or place it may have been sucking air
What you guys think sound about right
Old Jan 29, 2012 | 07:33 PM
probly just not spiining over fast enough. a new starter does wonders.
Old Jan 30, 2012 | 07:47 AM
Crazy's Avatar
Default Other update
well it wasn't starter it had air in the system again. but i think i made have found the problem the last cap on driver side was leaking couldn't see just looking at it in till i on top of the motor and could see fuel setting on the back of the block. Looks like when put the return lines on that pinch one of the O-Rings so put 2 new O-Rings on so i hope this fix my problem and think the starter was also part of the problem
gillespie3033
Chevy/GMC Duramax 01-04 LB7
29
Jun 25, 2015 03:51 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
J. Nick
Apr 24, 2015 01:13 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
