PLEASE help!! hard to start, and extremely sluggish behavior
Old Jan 22, 2012 | 07:12 PM
Ltk's Avatar
Ltk
Default PLEASE help!! hard to start, and extremely sluggish behavior
2003 Ford F250 Powerstroke 6.0L
It all started about 4 days ago... I start up the truck after school which means I have to cold start it after 8 hours of sitting in 20 degree weather.. The truck does its usual sluggish behavior when pulling onto the highway, but instead this time the smoke coming out of my stacks is blue. I was told a couple of months ago that my turbo was leaking oil, but I left it alone and figured I'd deal with it when I had to. Now the truck runs like HELL no matter how long I let it warm up. For a few miles the truck will pour blue smoke out of the exhaust and any time I hit the gas pedal it will not accelerate, it shakes violently and has epileptic fits on me. So after a day or 2 of this I was told by a friend of mine that is a diesel mechanic that my EGR valve could be coked up and stuck in the open position. Well I go through the 2 hour process of yanking the hell out of it without the proper tools to get it out and when I do it seems to be coked up VERY bad. I clean it until it shines and put it back in. The next day after that the truck ran perfect without any hesitation. This morning I go outside to start it and it has an extremely hard time starting (it was plugged in also and 60 degrees out when I woke up) after cranking it 5-6 times it starts up. I pull back onto the highway and it is doing the same thing again, blue smoke, no acceleration, violent shaking.
OK, so my questions are:
Is is possible that oil leaking into the turbo can cause the truck to not start easily, and the blue smoke and all that; or is it even a turbo problem at all??
Is there anything I can do besides buy a new turbo? I am 17 without a high-paying job and it is very hard to come up with $1500..
If the startup issue doesn't have anything to do with the turbo going out, what could the problem be here??
I am not an expert at working on engines as I'm only a few months into my diesel mechanics training, so things will have to be explained to me..
Thank you in advance, I need to figure this out ASAP before the turbo craps out on me and I am out of my only vehicle.
Old Jan 22, 2012 | 08:04 PM
wildbill's Avatar
Fuel issue. When was the last time the fuel filter was changed? Also, have you been getting fuel from a reputable station? If not, it's probably starting to gel (meaning the viscosity climbs to the point where it won't pump through the fuel filter).
Next chance, change the fuel filter, dump some Power Service 911 in the tank, then top off with #1 diesel.
Old Jan 22, 2012 | 08:08 PM
Ltk's Avatar
Ltk
i changed the filters about 2 days after it started acting up because i thought that was the issue. so they were changed about 3 days ago. i get diesel from walmart where I have always got it. but shouldnt plugging the truck in make it not gel?
Old Jan 22, 2012 | 08:29 PM
wildbill's Avatar
Plugging them in keeps the block warm, not the fuel.
You mentioned blue smoke from the exhaust. Does it smell like oil or fuel. Also did the CEL come on?
Old Jan 22, 2012 | 08:31 PM
03Powerstroke's Avatar
are you sure its blue, not white/gray?
Old Jan 22, 2012 | 08:33 PM
Ltk's Avatar
Ltk
Oh, sorry :P
the only time i see the blue smoke is in my rear view mirror when im trying to accelerate. so i cant smell it :/ the only thing i can think of is that if it's leaking oil into the turbo, thats shooting out of the exhaust so therefore i am almost positive it is oil.
nope, no CEL came on.. :/
yes it is solid blue smoke. not white/gray like on normal cold weather startups
Old Jan 22, 2012 | 08:36 PM
mine never smokes on cold starts, have you tested the FICM??
Old Jan 22, 2012 | 08:38 PM
Ltk's Avatar
Ltk
nope how can i test that? id imagine i have to have a tool right?
Old Jan 22, 2012 | 08:40 PM
wildbill's Avatar
No white/gray is good, means the coolant system is intact.
Old Jan 22, 2012 | 08:41 PM
Ltk's Avatar
Ltk
but the blue is either fuel or oil correct?
