Power loss under load
Old Jan 21, 2012 | 10:53 PM
Newbie's Avatar
Default Power loss under load
I have a 2002 Cummins with 5 speed transmission with an ongoing power loss issue under load. I have replaced the fuel pump system with and Airdog II system [preset to 17 psi] (no change) and replaced the VP44 injection pump ( more power empty) but still have an issue when pulling a loaded trailer. Sometimes it even loses power/speed going downhill. Can't get it to wind up. I KNOW it is capable of more because occassionally it will pick up power/speed going uphill in high gear. I actually have to let off on the throttle when I hit 75. Otherwise, it is pedal to the metal and constant shifting between 4th and 5th just to maintain 50-55 on level ground. I plan on increasing fuel pump pressure to see if it helps, but don't believe it will. Any suggestions?
Old Jan 21, 2012 | 11:58 PM
ajlester's Avatar
if your truck is smoking bad during all of this id check the turbo and its wastegate actuator. and do you have any codes? good be a number of things causing this problem.
Old Jan 22, 2012 | 12:59 AM
01quadcab's Avatar
your fuel pressure is fine. try cleaning your map sensor.
Old Jan 24, 2012 | 08:49 PM
Newbie's Avatar
No codes and no smoke that I am aware of. Been driving at night so hard to see. Getting ready to make another trip so I will watch closer. Thanks
Old Jan 26, 2012 | 07:01 AM
globalwarmingcontributor's Avatar
is there a loose intercooler boot maybe?
Old Jan 30, 2012 | 07:10 PM
sawdustmaker's Avatar
sounds like your going in and out of limp mode. check the codes. i forgot to plug my map sensor back in when i took my programmer off and this is how it drove.
Old Jan 30, 2012 | 10:56 PM
TTcummins99's Avatar
if you got a chip check the connections for it at the map sensor plug or it might be loose wire to your vp44
Old Nov 14, 2015 | 01:59 AM
willemse's Avatar
same problem here stock 99 with 6 tires vp44 was bad liftpump toast map and iat and crank and cam sensor replaced
still have same problem no power no leaks in my boots or intercooler i dn w =haTF is going in
i just keep dumping money
latest push on petal no go i think its time for the timbo apps
any one with the same problem let me know i am tired of it
little smoke when i start at a light is all i can tell you no codes except the apps low blah blah
HELP ME I AM 3000 in parts and still buying
Bighouse
Apr 9, 2015 06:51 PM
krg3590
Mar 15, 2015 08:57 AM
big tan snorkel
15
Dec 17, 2014 05:04 PM
Mattj29
Nov 26, 2014 07:17 PM
