9 starters 3 flywheels? why!!
Old Jan 13, 2012 | 02:26 PM
mrmarkman's Avatar
Default 9 starters 3 flywheels? why!!
my starter on my 1996 k2500 chevy went about 3 years ago mavis tire replaced it with advanced auto new starter . fine. a month later starter went again, it was a new one my regular mechanic replaced it with a new napa. since then i have replaced it 7 more times with new and good oem gm starters and then 2 flywheels until i went to a new mechanic and he said hole in block is not right and starter is always moving and eats teeth off flywheel. he put a block of wood to hold it but i will not drive it now. what can i do? i put in 3rd flywheel and 9th starter. i am sick!!:
Old Jan 13, 2012 | 02:31 PM
Crazy's Avatar
Are you running the front bracket on the starter if not you need to
if it the bolt holes out round you can try going up one sizes that mean drill tap and have drill the holes on the starter also
Also make sure the starter bolts being TQ at 40 FT lbs if they not this could be some of the moving going on
Old Jan 13, 2012 | 02:43 PM
mrmarkman's Avatar
thanks will ask him but i thought he said too much torque to drill out holes?
Old Jan 13, 2012 | 03:01 PM
outerdarkness's Avatar
Mine did this until I bought a set of ARP bolts. You may need to invest another couple hundred at the salvage yard for another engine.
Old Jan 13, 2012 | 03:04 PM
mrmarkman's Avatar
what are arp bolts and where do i get them/ thanks.,
Old Jan 13, 2012 | 05:35 PM
Crazy's Avatar
www.arp-bolts.com
Old Jan 13, 2012 | 05:41 PM
mrmarkman's Avatar
thanks called them but do not know bolts size till monday., how did this help you? what does it do better than oem bolts?
Old Jan 13, 2012 | 05:47 PM
Crazy's Avatar
ARP bolts lot better
One ? i for got ask you did they put new starter bolts in when they put new starter ? You never used old bolts they tren to bend and weaken and break
Old Jan 13, 2012 | 05:54 PM
mrmarkman's Avatar
the first 7 no they kept shimming and ruining it i was told the last guy bought oem chevy bolts but still not great. a piece of wood is holding the starter but thats not good. what does those arm bolts do?
Old Jan 19, 2012 | 11:33 PM
fordcummins79's Avatar
retap the bolt holes to sae thread instead of the metric one size bigger to take the slop out of it there is plenty of meat there to do so
