Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
EGT sensor to gauge lead wire
Old Jan 11, 2012 | 02:18 PM
AdrianD's Avatar
Default EGT sensor to gauge lead wire
Is there anything special with a lead wire for an EGT gauge, apart from high-temperature resistance ? Or can I use any wire as long as it's not close to a heat source ?
I personally don't feel comfortable spending extra dime only because of higher temp capability and would rather have a custom length of wire
Old Jan 11, 2012 | 07:28 PM
white93's Avatar
You have to use the wire thats meant for pyrometers, can't make your own. If you use anything but that your gauge wont be accurate if it even works.
Old Jan 12, 2012 | 09:32 AM
AdrianD's Avatar
Thank you
I'll get the wires then.
Old Jan 13, 2012 | 05:59 AM
CSIPSD's Avatar
Depends on who's gauges you are installing. Isspro EV-2 and Performax you can shorten to length that you want.
Autometer can not, or the gauge will read off.
Old Jan 13, 2012 | 10:06 AM
AdrianD's Avatar
Planning on ISSPRO EV-2. I can live with coiled up lead wire
Old Jan 14, 2012 | 01:37 AM
CSIPSD's Avatar
You dont have to with the EV-2... Cut it to length... Clean and nice install that way!
Old Jan 15, 2012 | 01:00 PM
white93's Avatar
Cool, I learned something new. I thought it was all pyro's you couldn't modify the lead wire. Maybe that only applies to the mechanical type and some others.
TurboBoy6.5
Apr 12, 2015 11:22 PM
MrCat4974
Mar 23, 2015 11:30 PM
