Need Compatibility Help
so i found a 1500 V8 similar to age to the 3500 i own, but it (among other parts that the 3500 is needs) has Air conditioning, so the question i pose to you gentlemen can the hvac system from the 1500 to the 3500?,
Also does the 1500 use the same TPS as the heavy dutys to run the trans?
im gonna assume your refering to your 91, no the TPS wont work, gas TPS is 28 bucks, the diesel TPS is 200 at the cheapest, replace it with a potentiometer, its a normal modification......AC compressors are different also.....
myago92
Oct 17, 2014 08:50 AM
