6.5l cuts out
Old Dec 30, 2011 | 08:54 PM
mpd310's Avatar
Default 6.5l cuts out
I have a 1995 6.5l 3500 GMC the problem is it cuts out at steady throttle around 55 mph doest stop running just bucks coughs then goes on. Problem is intermittent. A check of the computer shows the boost sensor bad but really dont think it sould cause the problem
Old Dec 31, 2011 | 10:33 PM
Red_Rattler's Avatar
High Tech Redneck
Thats the map sensor, it tells the ecm whether to fuel or defuel. Than can def be the problem.
Old Jan 1, 2012 | 02:37 PM
ebarresi5894's Avatar
aside from the map sensor check your lift pump and ops
my truck i would keep the throttle and it would do the same thing. put a new ops in and it stopped
Old Jan 2, 2012 | 05:44 PM
mpd310's Avatar
Default THANKS
Thanks for help will give those a try will let yall know
Old Jan 5, 2012 | 10:01 AM
Crazy's Avatar
What is the code you are getting gave little more info are you getting black
Check the OPS and LP just like ebarresi5894 said
sjslhill
Jul 22, 2015 01:02 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
HeavyChevy95
Jan 11, 2015 04:31 PM
Fishy816
Jan 11, 2015 08:31 AM
95 Sub
Jan 3, 2015 07:44 PM
