6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
waste vegetable oil & kerosene problem
Old Dec 28, 2011 | 01:04 PM
kayakguy7's Avatar
Default waste vegetable oil & kerosene problem
I recently used a blend of 3 Gallons of waste vegetable oil with 1 G kerosene, I used 7 gallons worth of that mix with 3/4 a tank of diesel. That worked well I added a 5 gallon blend of oil & kero more to the tank while it was running, It died while it was running, I emptied tank dropped it & replaced with B20 out of the pump from station drove it about 5 miles & it lost power & wont start. What could be the problem? Please help!
Old Dec 28, 2011 | 03:17 PM
Billy D's Avatar
Check your fuel filter
Old Jan 4, 2012 | 02:09 AM
kayakguy7's Avatar
Checked the fuel filter b4 draining tank. Where is the fuel pump on a 96 silverado the FI?
Old Jan 4, 2012 | 06:45 AM
MX02's Avatar
The lift pump is mounted on the inside of the frame rail approximately below the drivers seat.You should check the oil pressure switch for proper operation the gauge on the dash can work fine but the fuel pump switch portion can be bad.
Old Jan 25, 2012 | 09:47 PM
kayakguy7's Avatar
it cut out when i poured in the kerosene wvo mix
burndiesel
10
Feb 7, 2023 01:15 AM
vin_diesel
Mar 1, 2016 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
