injector HELP
Old Dec 18, 2011 | 09:04 PM
redneck512's Avatar
Default injector HELP
i got a 92 f350 i am trying to sell. i have a few problems with it i cant start it from them key i have to use a screwdriver under the hood on that part i dont know what it is called it has 3 bolts on it and wires that go to the batt and the starter. is my starter bad. next when you turn the key over and wait for the wait to start light to go off one of the injectors makes a clicking sound. is it a bad injector. please help i need to sell this thing quick.
Old Dec 18, 2011 | 09:42 PM
godblessmud's Avatar
The clicking sound is your glow plug relay, the clicking is normal. And what you are jumping is a starter solenoid. If it starts when you bridge the terminals your starter is fine.
Im going to guess you have a tilt steering wheel, the connections from the key/tumbler to that solenoid get broken in the steering column frequently in 8th generation fords from the stress if being tilted/moved over the years. (think bending a paper clip enough times, it breaks)
Old Dec 18, 2011 | 09:45 PM
redneck512's Avatar
yes it does have tilt. how do i fix that.
Old Dec 18, 2011 | 09:56 PM
Crazy's Avatar
i check to see if the small wire at starter solenoid getting power first before tilt apart could just bad solenoid
