Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
Looking into getting a 6.4
Old Dec 5, 2011 | 04:38 PM
jcfuzzdog29's Avatar
Default Looking into getting a 6.4
Looking to get not only my first diesel but a 6.4l. Was just wondering what some pros and cons are i have done some reasearch on them and it looks like mpg is the biggest compliant. What kind of mpgs are these trucks capaible of getting highway. How do they handle power add ons and what not hows the tranys in them. just looking for some good info on them. Thansk ahead of time
Old Dec 5, 2011 | 05:15 PM
03Powerstroke's Avatar
with dpf delete and tuner they can get around 20, way better than most 6.0's
Old Dec 5, 2011 | 05:29 PM
austin2592's Avatar
x2
Old Dec 5, 2011 | 06:43 PM
gunman41mag's Avatar
Moderator
6.4 tranny is strong, just make sure you drain the water out of the fuel once a/month, change the oil every 5,000 miles, & don't go more than 15,000 miles without changing both fuel filter & you'll be ok
Old Dec 6, 2011 | 09:33 AM
thanks for the quick resposne. any other info would be greatly appreciated
Old Dec 6, 2011 | 09:56 AM
Mdub707's Avatar
Stock, the power is ok, mileage is horrible.
A DPF delete and custom tuning will unleash the beast. Mileage will improve greatly (12-13 stock, unloaded, tuned they're closer to 17-20). You can tune up near 600rwhp. The stock trans will take pretty much anything you can throw at it, AS LONG as you have good tunes. Tuning is key to the life of the trans.
The downfalls are they're not the easiest to work on... cab needs to come off for nearly any major repair.
The fuel systems are extremely expensive on these, stay on top of fuel filters and use quality fuel.
Old Dec 6, 2011 | 10:40 AM
Moderator
I only put ULSD in my 6.4, I don't put any biodiesel
Old Dec 6, 2011 | 07:43 PM
how about being used for a dd and reliabilty.
Old Dec 6, 2011 | 07:48 PM
like i said, with upgrades better than a 6.0... so you could proly get 14-15+ depending on how you drive
Old Dec 6, 2011 | 07:51 PM
Moderator
I bought my 2008 F-250 6.4 NEW in 10/23/ 2008, I've only had one code in 3 years 2 months & it was the DPF, but I drove it hard & code left (I bet it was a dirty DPF)
