More 1st Gen Part Numbers.....
Old Jan 19, 2008 | 09:03 PM
LOGANSTANFORTH's Avatar
Default More 1st Gen Part Numbers.....
Delphi/Lucas POD Injectors
Cummins Part #3802335
Recon#3802335RX
Delphi Part# 6760524
Specs For the POD Injectors:
Supplier # LJC6760524
Cummins Nozzle # 3919316
Supplier Nozzle # 6801127
Nozzle Opening Pressure (Bar) 260
6 Cylinder CPL # 940
Tip Diameter = 7
PDC Kit 3802335
These injectors were used for Engine CPL 940 which is classified as turbocharged yard trucks.
Throttle Bellcrank Bushings
These are the replacement bushings for the throttle bellcrank. If your bellcrank has alot of play, these will fix the problem.
Dodge Part# 4425053 Retail for $1.95 each. You will need two.
VE Gasket/Seal Kit
Part # DGK121 (Bosch) expect to pay around 15-20 bucks.
Vacumn/Power Steering Pump Oil Seal Kit
Cummins Part # 4089842
Upgraded Cummins Piston Transfer Pump Kit
to replace diapraghm pump (piston type is used on P7100 systems, however, psi is lower to accomadate the VE pump
Cummins Part # 3936320 lift pump (qty 1)
# 3914753 Fuel Line (qty 1)
# 3931348 Gasket (qty 2)
# 3914284 Spacer (qty1)
# 3918191 Seals (qty 2)
Lift pump block off plate This is installed where the mechanical lift pump would go if you were upgrading to an electronic pump and needed to block the mechanical lift pump hole. Cummins Part # 3863441
Getrag Rear Seal For 2wd (all year models)
Chicago Rawhide Part # 19762
Throttle Linkage Rod & Ends
Cummins part# 4089076. This includes the rod, the 2 nuts, 2 steel ends and the new ball that the one snaps on. Price was $21.82.
Fuel Shutoff Solenoid
028-130-135-B
36.00 from
Valley Wagon
Carson City NV
Phone Number 775-882-2350
Oil Psi Sender
Cummins Part# 3923200
VE Pump Breakover Spring
1-464-651-430
3200 RPM Gov Spring
most places......also called the 366 spring
Belt Tensioner
Cummins Part# 3935819
Spicer U-Joints
5-160X
Updated Thermostat for 89-93 models
Cummins Part# 3802968
Speedometer Sensor
Napa Part# VSS100
Updated Flex Plate
This is the part number for a 95 model. This is a direct bolt on for the 1st gens and should be used in place of the old part number for added durability especially on modified trucks.
Chrysler Part # 5015709 Price $295.00
Cummins Part #3946161 Price $ 94.22
Carter Electronic Lift Pump (replaces stock unit)
block off plate for old pump is needed. plate for a 350 Chevrolet engine can be used. http://store.summitracing.com/partde...=CRT%2DP4600HP
Intake Heater Relay
(Discontinued thru Dodge but available thru Grainger and Misc other electrical suppliers) White-Rogers Relay Part #120-105111-1 with a coil of 12V DC cont. 9370. Stancor Relay Part #120-901
http://www.kubicki.tv/GridHtrSolenoids.pdf
http://www.stancor.com/pdfs/pg91_92.pdf
Upgraded OEM Fan and Fan Clutch
Dodge has issued an updated Fan which has more twist on the blades and is lighter. If you plan on upgrading your fan clutch, I strongly suggest you also upgrade to this new fan. Again, this is an OEM component from MOPAR.
Fan #52026653
Clutch module #52028760
Old Jan 20, 2008 | 01:15 AM
TCU Fan's Avatar
Aaron
Nice list Logan. Keep em coming.
Old Jan 1, 2010 | 06:58 PM
440warwagon's Avatar
Logan,do you have a part number for a first gen fan bearing?I have been searching all week! I finally found a Case number J910739.It mached my old bearing but cost $138.00.The local parts stores and bearing supply could not cross my old bearing number.
Thanks for the list!
Old Jan 1, 2010 | 08:07 PM
ArizonaRedneck's Avatar
thanks logan
Old Jan 1, 2010 | 08:23 PM
big bad diesel 416's Avatar
Site Sponsor
028-130-135-B
36.00 from
Valley Wagon
Carson City NV
Oil Psi Sender
1-464-651-430
3200 RPM Gov Spring
1-464-650-366
Belt Tensioner
Spicer U-Joints
5-160X
Moog Front Springs for D350
Heavy Duty 7226
Super Heavy Duty 7226S
Moog Front End Parts for 92 D350 (possibly will work for 91-93)
1. K7055 Idler Arm $72.95
2. K7082 Upper Ball Joint $53.95 each
3. K7053T Lower B/J $52.95 each
4. K7079 Strut Rod Bushing kit $18.95
5. K7192 Lower CTRL Arm bush. $23.95 each
6. K7104 Upper CTRL Arm bush. $21.95 each
7. DS1173 Drag/Center link $74.95
8. ES3123L Inner Tie Rods $36.95 each
9. ES3122R Outer Tie Rods $29.95 each
10. ES3124s Adjusting Sleeves $ 9.95 each
11. K7226 Frnt HD Coil Sprgs $79.95 for the pair.
Speedometer Sensor
Napa Part# VSS100
Updated Flex Plate
Carter GP4600HP - Carter Universal Rotary Vane Electric Fuel Pumps - Overview - SummitRacing.com
Intake Heater Relay[b] (Discontinued thru Dodge but available thru Grainger and Misc other electrical suppliers) White-Rogers Relay Part #120-105111-1 with a coil of 12V DC cont. 9370. Stancor Relay Part #120-901
[b]Upgraded OEM Fan and Fan Clutch
Fan- 52026653
Clutch module- 52028760
93-88 2wd truck numbers:
centerlink DS1173
adjusting sleeve ES3124S
right outside tierod ES3122R
right inside tierod ES3123L
left inside tierod ES3123L
left outside tierod ES3122R
idler arm K7055
upper balljoint K778, K7082(HD)
lower balljoint K7025(must replace with K727 if it has 4 wrench flats and is screw in), K7025T(enhanced design), K7053T(HD)
upper control arm shaft kit K7036
upper control arm bushing kit K7006(2 required per truck), K7189(1 kit per truck, performance busings), K7104(eccentric bushing kit for more camber)
upper control arm bumpstop K7293
lower control arm bushing kit K7077(2 kits per truck), K7193(1 kit per truck, performance bushings)
HD lower control arm bushing kit K7065(2 kits per truck), K7192(1 kit per truck, performance bushings)
lower control arm bump stop K7282
sway bar to frame bushing K7096
sway bar link repair kit K7081
rear leaf spring bushing 1" O.D. x 1/2" I.D. SB266
rear leaf spring bushing 1 1/2 O.D. x 3/4" I.D. SB268
93-88 4wd truck numbers:
upper ball joint K8194T
lower ball joint K8195T
bump stop K7282
lower kingpin K992(provides 1 1/2 degree of camber adjustment)
lower kingpin bearing kit K8832
upper kingpin bearing kit K6652
sway bar to frame bushing with 1 1/16 bar K7302
both sizes are thermoplastic bushings
sway bar to frame bushing with 1 3/16 bar K6172
swaybar link repair kit K7081
right tierod ES2010R
left tierod ES2010L
draglink DS914
adjuster tube DS1411S
front leaf spring bushing front and rear SB266
head gasket 9332PT
head set w/o gasket HSU9332
gasket conversion set CS9332 (includes oil pan gasket)\
exhaust manifold gasket set MS92089
exhaust pipe gasket 60928
oil pan gasket OS34102
rear main seal and gasket set BS40633
valve cover gasket set VS50396R
pushrod cover gasket set PS50397R
valve stem seal SS70819-1
water outlet o-ring 35526
water pump gasket 35525
timing cover gasket TCS45902
anchor industries motor mounts
2wd
front motor mount 2710
tranny mount N/A
4wd
trans upper mount 2667
trans lower mount 2668
Carlson Brake Part Numbers
D250 w/ 12x2.5 drum
front
disc hardware kit H5516
pad shim kit 18063
caliper repair kit 41099
bleeder screw H9402
caliper piston 7535 for phenolic, 7501 for steel
caliper support spring H5315
inner bushing H5209
rear
drum hardware kit H7199
brake drum pro kit H2316
guide pin H4087
bolt sleeve H547
adjustment screw spring H430
self adjuster repair kits H2598 left, H2599 right
wheel cylinder repair kit 45004
hold down pin H1119
hold down spring H1164
adjuster lever H2049 left, H2048 right
cable guide/pivot H2093
cable H2104
lever return spring H2140 left, H2141 right
adjuster screw assembly H1534 left, H1535 right
D350 w/ 12x2.5 drum
front
pad shim kit 18063
bleeder screw H9402
inner bushing H5209
rear
guide pin H4087
bolt sleeve H547
wheel cylinder repair kit 45004 for 7/8" wc bore, 45002 for 1" wc bore
hold down pin H1119
cable H2104
D350 w/ 12x3 drum
front
pad shim kit 18063
bleeder screw H9402
inner bushing H5209
rear
guide pin H4087
bolt sleeve H547
wheel cylinder repair kit 45002 for 1" wc bore, 45019 for 1 1/16" wc bore
hold down pin H1119
cable H2104
Four Seasons Temperature Control Products
system specs R-12, refrigerant capacity 44 oz., oil capacity 4.6 oz for 93, 7.25 oz for 92-89
blower motor w/ A/C 35474
blower motor w/o A/C 35560
93-92 SDB709 type compresor w/ clutch S57562
91-89 C171 type compressor w/ clutch 57106
non-intercooled condenser 53298
intercooled condenser N/A
evaporator core 54108
expension valve/orifice tube 38849
intercooled fan clutch 36936
non-intercooled fan clutch 36705
filter drier/accumulator 33555
heater core w/ A/C 94619
heater core w/o A/C 94600
93-90 tensioner assembly 45844
89 idler pulley 45981
clutch cycling switch R-12 35800
clutch cycling switch R-134a 36677
coolant temp sensor 36425
low pressure cut out 35752
water outlet 85181
tranny coolers:
Ultra-Cool
light duty 53000
medium duty 53001
heavy duty 53002
Rapid-Cool
light duty 53005
medium duty 53006
heavy duty 53007
Modine Radiators, Condensors, Heater Cores
specifications
core size 25 3/4 x 21 x 2 1/4 (3row)
inlet header 2 5/8 x 21 1/4
outlet header 2 5/8 x 21 1/4
inlet connection 1 3/4 left
outlet connection 2 right
pin mount
93-92 radiator 2460
93 condenser 300034
92-90 condenser 300031
89 condenser 300025
heater core 702463, 702464
heater core specifications
702463: 8 x 6 1/2 x 2, inlet/outlet 5/8, in/out is beside core
702464: 8 x 6 1/2 x 2, inlet/outlet 5/8, in/out is above core
Texas Diesel
Sep 4, 2018 12:24 AM
Cdog121
Nov 16, 2015 01:49 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
ajpt6.9
Dec 4, 2014 12:06 PM
myago92
Oct 17, 2014 08:50 AM
