12v in 1990 f350 issue
Old Nov 26, 2011 | 02:12 PM
94cummins12v's Avatar
Default 12v in 1990 f350 issue
ok ive had my truck done now for almost 2 years ever since i put the cummins in the ford iv had very low to no boost ive noticed my egts are higher than in the dodge and i dont have the low end spool up turbo makes at about 10-15 loades rely pushing it with the size turbo i have and fuel mods i was making 40psi+in the dodge since i started diagnosing i have done a 3piece ported manifold, ported turbo and custom high flow downpipe and no change could it be to small of fuel lines? thats the only thing else i can think of because you need fuel to make boost and boost to make more fuel?
Old Nov 26, 2011 | 05:50 PM
tomduelly's Avatar
high egt's makes me think of air flow. I would check exhaust back press. Is exhuast system adequate? Still have original muffler or cat. You have to let the air flow out if you expect to get the air in. Really sounds like exhaust restriction to me.
Old Nov 26, 2011 | 11:23 PM
white93's Avatar
^^^ He has a good point. I would pressure check the the intercooler and all that other stuff. If not that i would check the inlrt screen on the lift pump. I had a friend with a similar problem and he changed a few filters and almost a lift pump before he noticed the screen was partially blocked.
Old Nov 27, 2011 | 09:39 AM
dont think so i ported the manifold and turbo exhuast housing and have a custom 4" downpipe to 5" straight pipe with no cat or muffler same exhuast that was on the dodge
i pressure checked the entire intake system yesterday and no leaks as for the screen i will double check that and the fuel filter first then go from there
Last edited by 94cummins12v; Nov 27, 2011 at 09:39 AM. Reason: Automerged Doublepost
Ric Stokes
Sep 11, 2015 01:29 PM
Cavnar
Sep 9, 2015 07:18 PM
DBHX0311
Jun 19, 2015 11:57 AM
atreefunk
For Sale
Apr 13, 2015 10:57 PM
Mayhem
8
Jan 15, 2015 12:02 AM
