12v in 1990 f350 issue
Old Nov 26, 2011 | 02:10 PM
94cummins12v's Avatar
Default 12v in 1990 f350 issue
ok ive had my truck done now for almost 2 years ever since i put the cummins in the ford iv had very low to no boost ive noticed my egts are higher than in the dodge and i dont have the low end spool up turbo makes at about 10-15 loades rely pushing it with the size turbo i have and fuel mods i was making 40psi+in the dodge since i started diagnosing i have done a 3piece ported manifold, ported turbo and custom high flow downpipe and no change could it be to small of fuel lines? thats the only thing else i can think of because you need fuel to make boost and boost to make more fuel?
Old Nov 26, 2011 | 02:12 PM
daveO's Avatar
I guess it could be possible. I would see where your fuel pressure is at and go from there.
Old Nov 26, 2011 | 02:16 PM
well i do remember in the dodge with the pump turned all the way up i could flat black out a freeway in my older age im going for power not smoke. i turned the pump all the way up yesterday and still seems to be lacking the boost situation is still the same , i did an intake system check and no leaks
Old Nov 26, 2011 | 08:06 PM
white93's Avatar
Do you have a draw straw or anything like that in the tank? Its possible the pickup in the tank could be too small causing a restriction.
Old Nov 26, 2011 | 08:41 PM
deck60's Avatar
Default fuel tank
I have heard that the screen in a gas truck will not let enough fuel through for a diesel might try a electric lift pump you have to move 90 gallon an hour the stock manual pump provides 90 gal hr at 7-12 psi depended on the rpm when my lift pump went out for the 3rd time I replaced it with one similar to this
ebay item # 390367125264
might be a good test or put a psi gauge on to test pressure
Old Nov 26, 2011 | 11:12 PM
tomduelly's Avatar
I posted a reply to this in the distress thread that i don't want to re-type
Old Nov 27, 2011 | 09:41 AM
well the entire ford fuel system up to the lift pump is what im running and the truck was a 7.3 non turbo diesel im gnna check the lift pump screen and change the fuel filter and see what happens i dont have a draw straw but if its the fuel system thats next on my list i would like to find the cause before i get to redoing the entire fuel system especially with dual tanks
Old Dec 4, 2011 | 09:00 PM
not enoughsmoke's Avatar
is it smoking worse?black?white?
Old Dec 15, 2011 | 02:39 PM
well im leaning toward low fuel do to the fact the fuel components im running and the pump maxed out it doesnt smoke black like it should normally i have everyhting tuned so i dont get smoke but when i built this truck i havent had the boost to tune it yet anyway im almost debating on running a bypass line into a tank with actual 3/8 rubber fuel line and see what happens. i dont exactly know what size ports the fuel valve is being dual tanks but im sure it does restrict to a certain degree. with the mods im running i was pushing 45psi+ with it in the dodge
Old Dec 16, 2011 | 09:19 AM
93_Fummins's Avatar
When I had my 1st Gen Cummins in my '93 F-250, I ran the stock Ford IDI diesel fuel system up to the lift pump on the Cummins and I never had a problem. However, when the sending units went out in the tanks, I dropped them and found out that the rubber funnel/baffel at the end of the pickup tubes were all "melted" and gummed up the end of the pickups. I did notice that when I put the 2nd Gen Cummins in and turned up the pump that it seemed like I could never get enough fuel to it with the stock 2nd Gen mechanical pump. I ended up getting an AirDog 150 and ran 1/2" line and a draw straw from the rear tank to the engine, and just use the front tank as a "transfer tank" with a small Carter fuel pump between it and the rear. I'm trying to come up with a way to make a 1/2" ID transfer valve assembly so I can straw the front tank and switch on the fly, but I've been pleased with the current system, especially since adding a 33 gallon rear poly Bronco tank.
