injector
Old Nov 26, 2011 | 01:55 PM
TOM81650's Avatar
Default injector
air bubbles around injector. Bad injector? i feel stupid asking just want to make sure before i order new ones
Old Nov 26, 2011 | 08:50 PM
DieselCrawler's Avatar
coming from where it threads into the head or up top where the plastic cap is? if it is up top order a return line kit from somewhere like oregon fuel injection or off ebay.
Old Dec 1, 2011 | 11:28 AM
TOM81650's Avatar
What is involved with replacing injector return lines?
Old Dec 1, 2011 | 03:38 PM
get a injecotor return line kit. unthred the metal line from injector, pull platic cap off. then take the 2 orings off. install new orings with some vasaline on them. install the cap and reintall the line. after getting all new caps on, then cut the hose to fit between the caps. takes me about 40 mins if it is NA. longer if it has a turbo.
Old Dec 1, 2011 | 06:00 PM
TOM81650's Avatar
But it's basically the same with both mines turbo
Old Dec 1, 2011 | 07:31 PM
yea, with the turbos it makes it harder to route the lines just becasue it can be in the way. depends on the turbo setup it has. i am going to guess yours is a stock ATS turbo.
Old Dec 2, 2011 | 07:32 PM
TOM81650's Avatar
Are there Any gaskets or orange in the fuel lines I should worry about when I pull them off
Old Dec 2, 2011 | 11:07 PM
nope. the metal feed lines are like a brake line. compression fittings.
Old Dec 3, 2011 | 06:02 PM
TOM81650's Avatar
Great thanks for the info
The rEturn line kit fixed alot of what was wrong thanks for Savin me a few hundred dollars
lowride
Oct 24, 2015 08:50 AM
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
5.9L 24V Performance
Mar 5, 2015 05:02 PM
J_stout
Dec 14, 2014 07:23 PM
