Injector ?
Old Nov 22, 2011 | 06:55 PM
Jwebb's Avatar
Default Injector ?
Noticed the other Day that I had a small amount of fuel coming from around the upper part of my injectors is there anything to watch out for when replacing these o rings I would think its pretty easy just want to make sure there isn't any special requirements
Old Nov 29, 2011 | 12:54 PM
McFadin1stgencummins's Avatar
I just started gettin this problem, and some one was tellin me I have to replace the whole injector. Guess not ?
Old Nov 29, 2011 | 06:54 PM
DieselCrawler's Avatar
dont just replace the orings. get the kit and replace the caps also. and lines. and no big worries. just make sure no dirt gets into the injector when u have the line off, and when installing the caps, put some vasaline on the orings and with a socket and little hammer, tap the caps on. they should have about a 1/16th of an inch between the injector line nut and the plastic cap when they are alll the way down. also check the insides of your new caps. make sure there is no sharp edges and the holes are clear.
Old Nov 30, 2011 | 10:41 PM
ok thanks
Old Dec 2, 2011 | 10:30 PM
Jwebb's Avatar
Replaced o rings and caps no more leaks thanks for the info
lowride
Oct 24, 2015 08:50 AM
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
5.9L 24V Performance
Mar 5, 2015 05:02 PM
J_stout
Dec 14, 2014 07:23 PM
